200 Stage 4 Dellorto JL3 jetting guide
Postby Covboy » Mon Sep 17, 2018 8:55 pm
Hello Chaps
My PC-phobic friend has a Stage 4 (whatever that means) 200 cc engine just back from a re-bore from AF-R , 30mm Dellorto, open mouth, JL3 exhaust, variotronic ignition
I'm sure many people have a similar set up - he would appreciate ballpark jetting details please as a starter for 10...
Many thanks
Steve
Re: 200 Stage 4 Dellorto JL3 jetting guide
Postby Rich Oswald » Tue Sep 18, 2018 3:47 pm
Covboy wrote:Hello Chaps
Many thanks
Steve
I take it that the carb is a 30mm phbh?
If so ballpark would be:-
300 float valve
118-122 Main Jet
70 choke
40 slide
50-52 pilot jet
AV266 Atomiser
X7 needle on 2nd clip from top
This is just a loose guide. Best to start rich and come down weaker if necessary. ALWAYS do several plug chops at all throttle openings.
Cheers and hope this helps,
Postby Covboy » Tue Sep 18, 2018 4:17 pm
thanks Rich
