hi all, I'm after suggestions/starting points for
rapido barrel
LTH reed
Boost ports
71mm wiseco H2 piston (reed holes cut)
60 stroke
115mm con rod
I have a PHBH 30mm and I'm looking for carb setup suggestions..
thanks
lofty wrote:hi all, I'm after suggestions/starting points for
rapido barrel
LTH reed
Boost ports
60 stroke
115mm con rod
thanks
