30mm Dellorto with 48mm reverse cone Clubman set up
Postby SlackerThePinstriper » Fri Jan 20, 2017 5:54 pm
Anybody know what I should be jetted at. Standard Indian 200 besides
Re: 30mm Dellorto with 48mm reverse cone Clubman set up
Postby MickYork » Fri Jan 20, 2017 6:57 pm
Every engine set-up is different and although a spec' may be the same the settings may be different.
I would start with: 40 slide, AV268 atomiser, x7 needle, 50 pilot, 118 main (probably too rich).
If it works right first time something must be wrong :D
Plug chop at various throttle positions and alter accordingly.
Postby SlackerThePinstriper » Mon Jan 23, 2017 2:28 pm
Cheers for that mate. I will save that for when I'm ready for it
Return to Carburettors
Users browsing this forum: No registered users and 36 guests
