Adjusting a PHBL 25
Adjusting a PHBL 25
Postby muddy » Thu Jun 04, 2015 3:29 pm
The tickover is a bit low and starting isn't the best so I thought I'd adjust the carb settings. There's 2 adjusters 1 larger one with a spring. The problem is were ever I tun these 2 screws there is no effect on the engine, any suggestions please.
muddy
Re: Adjusting a PHBL 25
Postby 2ndtimearound » Thu Jun 04, 2015 9:03 pm
I`ve just had a lot of messing with mine on a fairly standard TV175 see post below yours & hope I have now sorted it more or less. Have a look on the MB tech site , as there is a lot of info on there about the carb set up.
Basically your big screw should adjust the slide up/down depending on whether you screw it in/out & should increase/decrease revs (take the bellows off & you can see what happens). The small jet at the back adjusts the fuel at tickover/low speed & richens mixture screwing it out, weakens screwing it in. This screw shouldn`t be screwed out too far or it may fall out - have a look on the Broadhurst site - they will take you through it.
Happy reading/fiddling.
2ndtimearound
Postby muddy » Thu Jun 04, 2015 10:15 pm
Thanks for the info mate
muddy
Postby Cgt75b » Fri Jun 19, 2015 7:10 pm
The anti surge washer in the float bow, can this be removed without issue, or does it need too stay in there ?
Sorry for plonking on the end, didn't want to start another thread.
Postby rossclark » Fri Jun 19, 2015 8:40 pm
I'd say dellorto put that there for a reason, leave it be.
Postby Cgt75b » Sat Jun 20, 2015 2:20 pm
Fair point taken. But the question still remains is there any ill effects to running it without ? Innocenti built scooters that shouldn't go 100 mph but some do!
Postby 2ndtimearound » Tue Jun 23, 2015 12:54 pm
Maybe I`m blind, but I`ve had my PHBL 25mm to bits quite a few times changing jets & I`ve never seen an anti surge washer in the float bowl - I assume looking at the parts diagram it just sits over the jet to stop fuel slopping about when you`re going for it? :oops:
For what it`s worth, mine has been on a 190 cylinder & I never noticed any bad running on acceleration/cornering.
2ndtimearound
Postby northernpete » Thu May 12, 2016 11:07 pm
Can I ask what manifold you guys are using....I have a phbl 24as carb (same body I believe) and can't get a manifold to fit ( solid mount,185 barrel) :?
northernpete
Return to Carburettors
Users browsing this forum: No registered users and 32 guests
