30mm VHSH Jetting TS1
Postby Atb Tim » Sat May 31, 2014 3:07 pm
Just swapped my TMX35 for a 30mm VHSH.
Could do with some examples of jetting as a starting point please.
It's a 225 TSI with a Franspeed pipe.
Atb Tim
Re: 30mm VHSH Jetting TS1
Postby Toddy » Mon Jun 02, 2014 5:56 am
Hope this helps ,
Dellorto 30 mm Flatslide VHSH/ADS3 Filter
Slide 40
Needle K32 1st
Atomiser DQ266
Main Jet 148
Pilot 60
Choke 60
Float 126301 GR9 300 Brass (Needle Valve 300)
Dellorto 30mm Flatslide (Taffspeed) VHSH/Devtour No Filter
Slide 50
Needle K94 P4
Atomizer DQ269
Main Jet 160
Pilot 45 40
Choke 60
Float (Needle Valve) 300
Postby Atb Tim » Mon Jun 02, 2014 8:27 pm
Thanks Toddy,
I assume the set up with the filter has a hole in the panel?
Atb Tim
Postby Toddy » Mon Jun 02, 2014 8:51 pm
Yes mate ramair type
Postby Simon ELC » Sun Jul 13, 2014 9:07 pm
If it's any help to anyone my set up is:-
Tuned TS1, 30mm VHSH, NK Road pipe, No filter
Pilot 48 60
Slide 50
Needle K24
Atomiser DQ268
Main 125
I have an adjustable power jet fitted to overcome a lean spot at 3/4 throttle. I tried dozens of different needle/atomiser combinations but couldn't get rid of the leanness at 3/4 until I fitted the power jet. Hence the small main jet.
Never had any joy with DP atomisers in my TS1s always found them too rich low down.
Simon ELC
Return to Carburettors
Users browsing this forum: No registered users and 32 guests
