Spanish 20mm standard carb?
Postby serveta1 » Fri Dec 11, 2015 7:36 am
I've got an original Spanish 20mm carb, question is- it has a small rubber type washer fitted to the float valve, does this washer sit to the inner or the outer side of the float? Thanks in advance for any assistance.
serveta1
Re: Spanish 20mm standard carb?
Postby Digger » Fri Dec 11, 2015 9:03 am
I've got a couple - I'll have a look tomorrow unless someone else beats me to it.
Digger
Postby serveta1 » Sat Dec 12, 2015 10:47 am
Cheers Digger, much appreciated
serveta1
Postby Digger » Sun Dec 13, 2015 10:11 am
Just checked my two Spanish 20mm and an Italian one - none of them have any washer or rubber on the float valve?
Have you got a picture?
Digger
Postby hullygully » Sun Dec 13, 2015 12:56 pm
you must mean on the float chamber? :) as jetex carbs have a gasket
Postby serveta1 » Sun Dec 13, 2015 2:49 pm
definatly float needle/valve, I've not seen one on this part before either, also doesn't look like its something that's been added at some point??? Sorry haven't got a picture & have had to put carb back together, went for outside edge of float, (bound to be the other way!)fingers crossed.
Thanks again for advise.
serveta1
Return to Carburettors
Users browsing this forum: Bing [Bot] and 41 guests
