Inlet manifold
Inlet manifold
Postby Geocamper » Fri May 01, 2015 6:37 pm
Would a TV 175 series 2 original manifold fit onto a dellorto sh1/20 series 3 TV carb?
Geocamper
Re: Inlet manifold
Postby Dimitrios_231 » Sat May 02, 2015 7:32 pm
I have a TV2 manifold which is fitted with an extra collar,is this a common mod?
It has 31mm O/D,NOS S3 manifolds have 27.9mm O/D
Dimitrios_231
Re: Inlet manifold
Postby Dimitrios_231 » Thu Oct 15, 2015 10:48 pm
Back from the crypt :)
I was working on a TV2 today,
orginal manifold is 31mm O/D
It won't fit a SH1/20
In fact it won't fit a SH2/22 either,
next to a GP150 manifold,the GP manifold is smaller.
Dimitrios_231
Re: Inlet manifold
Postby hullygully » Fri Oct 16, 2015 10:41 am
rough sand paper/file it down for a few minuits :shock: :lol: :roll:
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 16, 2015 1:35 pm
Dimitrios_231
Re: Inlet manifold
Postby johnnyXS » Fri Oct 16, 2015 1:47 pm
thats an interesting mod .I would say that the collar has likely been added to allow the fitment of a non standard carburettor perhaps for racing ? i'm thinking maybe Amal ?
I just did a google search and interestingly came up with this reference to a 'larger inlet' series 2 175cc manifold 19.21.1016with a reference to modification .
Hope that it is ok to post a link to this as it is pertinant and Lambretta relevant? apologies if I've got it wrong again :roll: :roll:
http://www.minimoddesigns.co.uk/Shop/product.php/708/0
johnnyXS
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 16, 2015 3:18 pm
Τhe modified collar has the same O/D as the original,31mm,
I guess that the modified was worn and was out of service,
someone added the collar to make it usable again,
I'm not Mr.Holmes,I might be wrong ;)
Dimitrios_231
Re: Inlet manifold
Postby johnnyXS » Fri Oct 16, 2015 3:39 pm
could be ..but I can't see the aluminium spigot wearing to any significant extent by the action of the plastic bush in the carb inlet.
its a lot of work to turn a collar on a lathe
how did you come by it may I ask ? was it bought seperately or did it come with an engine you bought
johnnyXS
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 16, 2015 4:32 pm
It was part of a job lot :) ;)
Dimitrios_231
Re: Inlet manifold
Postby johnnyXS » Fri Oct 16, 2015 5:06 pm
:shock: :shock: :shock: Strewth !
I thought you must be a shop when i saw all those exhausts :lol: :lol:
johnnyXS
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 16, 2015 9:53 pm
Not a shop,
just lunatic :mrgreen:
Dimitrios_231
Re: Inlet manifold
Postby Wack » Fri Oct 23, 2015 7:43 pm
great chess set
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 23, 2015 9:23 pm
Cheers :)
The manifold is now cleaned,opened and matched to the inlet.
I smoothed the inside
In general I did some porting at the cylinder...
... and the crankcase
Next week,I'll send the cylinder for honing,fit new piston rings and do some extra chamfering.
Dimitrios_231
Re: Inlet manifold
Postby johnnyXS » Fri Oct 23, 2015 9:27 pm
not wanting to hyjack the thread but seeing as we are talking inlet manifolds ;)
My 150 LiS special 1964 came with a manifold that was stamped with a 175 ? :?
is it likely that it was fitted at the factory ? the engine No is 150Li* 73817#
Nice job on the porting Dimitrios ;)
johnnyXS
Re: Inlet manifold
Postby Dimitrios_231 » Fri Oct 23, 2015 9:52 pm
Thanks,if you look closely,it is the same as the one in the middle,19711004
The official parts catalogue for late S3 models,says that this manifold was for Li150 Special and TV175,so it is the correct one ;)
Fig 76
This is the 'beast' :)
my Rapido's 252.43cc piston ported inlet for Amal's MK1 custom manifold.
Dimitrios_231
Re: Inlet manifold
Postby johnnyXS » Sat Oct 24, 2015 10:08 am
[quote="Dimitrios_231"]Thanks,if you look closely,it is the same as the one in the middle,19711004
Fig 76
Thanks Dimitrios thats put my mind at rest. They were obviously happy to raid the parts bin for the early Li 150 specials :roll:
I had half been hoping that it was a replacement 175 engine but it looks like it is the original engine afterall.
Thank you for the parts table .
This thing you're building truly is a beast ! 250cc ! :o wow you're gonna have to hang on to that one for dear life ... :lol: :lol:
johnnyXS
Re: Inlet manifold
Postby Dimitrios_231 » Sat Oct 24, 2015 2:41 pm
I use this cylinder the last five (or more) years,
It started it's life, somewhere in England,
I've opened it two extra times to play with the ports,
pics are from the last surgery :)
165 degrees inlet,it is quite thirsty :lol:
Dimitrios_231
Return to Carburettors
Users browsing this forum: Bing [Bot] and 41 guests
