Larger or smaller
Larger or smaller
Postby Norfolk » Tue Jul 21, 2015 9:23 am
Hi Guys,
I currently have a Muggy 186 with a PHBH 26 carb with the following carb set up:-
Main 104
Pilot 48
Atomiser AV266
Needle X7, second clip
Slide 40
Choke 70
Varitronic ignition set at 19 deg
The engine idles best when the mixture screw is fully screwed in and previous threads indicate "Closed to 1/8 throttle - air screw and pilot/slow jet", question is do I need a larger or smaller pilot jet or am I barking up the wrong tree, also....
Reving the engine up to approx 3500 rpm, the engine then gives a very distinct jolt and from on then reves very smoothly.
Any thoughts please, thanks
Norfolk
Norfolk
Re: Larger or smaller
Postby CHRIS in MARGATE » Tue Jul 21, 2015 10:41 am
When you try to rev from idle to 3500 rpm does it sound breathless or does it gurgle and 4 stroke?
If it's breathless you need a larger pilot. If it's lumpy and 4 strokes you need a smaller pilot.
But .... you must get it right and keep checking plug colour.
Postby Rich Oswald » Tue Jul 21, 2015 12:57 pm
I wouldn't recommend running with mixture screw full in. You are obviously too rich on the pilot and trying to weaken it so you need a smaller pilot jet. (I think that's the right way round).
Postby coaster » Tue Jul 21, 2015 9:04 pm
I'm not an expert on the Varitronic but 19 degrees static sounds a bit too retarded for a variable ignition, thought maybe 22 or 23 would be nearer the mark :?
Postby Norfolk » Tue Jul 21, 2015 10:52 pm
Hi guys,
Many thanks for your thoughts, it has given me something to work on.
Regarding Coaster's comment of ignition timing, it is set at 19 deg with a strobe light and the engine running at a fast idle, from other threads of engines overheating and seizing, I thought this was best or am I becoming paranoid.
Norfolk.
Norfolk
Postby dickie » Wed Jul 22, 2015 5:26 am
Norfolk wrote:Hi guys,
Norfolk.
Coaster is right with 19 at fast tickover it will retard to 11 at 6000 rpm; way too much.
23 could be too advanced if you spend all your time at low rpm, in which case you don't really need variable ignition.
Postby skinnerwill » Wed Jul 29, 2015 9:56 am
as above ,sounds like pilot needs changing, mixture screw shouldn't be screwed right in, and yes do plug chops
skinnerwill
Return to Carburettors
Users browsing this forum: No registered users and 52 guests
