28ml PHBH four stroking
Postby steve_lawrence » Wed Jun 11, 2025 7:38 am
I recently had an RT195 kit fitted to my Li Special. It has a brand new Dell’Orto PHBH 28ml carb which is proving virtually impossible to set up for a non-spluttery ride. My friend, a motorcyclist and scooter rider for many years has tried many jetting set ups but it has got him beat. The scooter goes well, but once you ease back on the throttle the 4 stroking kicks in. Under load it’s fine, but ease off to steady the speed and that’s when the issue starts. Would a dyno session possibly cure it?
The current set up is 50 pilot, 126 main, X13 needle second clip from the top, 264 atomiser. I’m not using the air box but there’s a foam air filter fitted directly on the carb.
Any advice would be gratefully appreciated.
steve_lawrence
Re: 28ml PHBH four stroking
Postby hullygully » Wed Jun 11, 2025 9:44 am
Ive used a 55/57 pilot in 2 x mates 28mm dellies on rt195's but with open carb
what's your air screw & slide bud, plus exhaust?
have you tried without filter?
Postby steve_lawrence » Wed Jun 11, 2025 1:59 pm
It’s a 40 slide. I’m not near the scooter at the moment so I can’t check the air screw.
steve_lawrence
Postby Adam_Winstone » Wed Jun 11, 2025 9:59 pm
Leaking float with fuel in it?
Postby Warkton Tornado No.1 » Thu Jun 12, 2025 10:16 am
The slide is too rich. Dell’Orto carburettors - perhaps unsurprisingly - tend to need the same slides across the range & 45 is the normal choice.
If possible, borrow a 45 slide to try.
The good news - apart from it having a round slide :roll: - is that the 40 slide is easily convertible to a 45 via material removal from the edge…..
Postby Rich Oswald » Thu Jun 12, 2025 6:03 pm
A 45 or even a 50 slide would probably help your issue.
Postby hullygully » Fri Jun 13, 2025 10:06 am
there is also another range of atomisers, the AS range as opposed to the AV's, which have the same no. range but are slightly weaker :shock:
Return to Carburettors
Users browsing this forum: No registered users and 3 guests
