Scootopia Float & Plunger Kit
Postby hullygully » Thu Dec 05, 2024 12:16 pm
has anyone had any problems with the above?
we bought the above kit (came with black tipped plunger :roll: ) & tried to fit into a SH1/20 Delly carb, no success.
the plunger kept sticking so used an original red tipped plunger, success, but, when fitted back on scoot it spewed out fuel within 5 secs :shock:
stripped again, placed float in cup of water & it floated.
compared dimensions of new black scootopia float to an original 5gr float. original is slightly smaller in height, scootopia pivot position is slightly higher :o
put original red tipped plunger with original float & hey presto, no leak from the over flow. 8-)
Re: Scootopia Float & Plunger Kit
Postby Cgt75b » Mon Dec 09, 2024 3:51 pm
You know what they say.
Postby Scooterslag » Tue Dec 17, 2024 12:52 am
hullygully wrote:has anyone had any problems with the above?
Yep had similar problems with the scootopia kit, tried chopping over a few different needles and float bowls ( scootopia and OEM) no joy- bloody thing kept sticking and leaking :evil: in the end I tried a red tipped needle and a clear plastic float bowl from a Jettex carb which ( fingers crossed) has done the trick. What a bloody faff! Paul :x
Postby Adam_Winstone » Tue Dec 17, 2024 2:42 pm
^... watch out for possible fuel starvation as some of the red-tipped aftermarket needles are a fraction longer than the originals.
Return to Carburettors
Users browsing this forum: Google [Bot] and 37 guests
