Clearance
Clearance
Postby L111amo » Thu Jul 01, 2021 8:07 pm
Hi all, mates just fitted a185 scootopia kit with 28 mm carb, he’s go clearance issues with carb close to panel(can’t fit any filter etc) any ideas, cheers liam
L111amo
Re: Clearance
Postby Rich Oswald » Thu Jul 01, 2021 8:49 pm
Either try a Chiselspeed panel filter or run it open mouthed.
Re: Clearance
Postby L111amo » Thu Jul 01, 2021 10:27 pm
Cheers for that, he is running open at moment but doesn’t like it, will have a look at those, cheers bud
L111amo
Re: Clearance
Postby Tractorman » Fri Jul 02, 2021 9:08 am
The Casa filter is good and fits well under the panel.
Re: Clearance
Postby hullygully » Mon Jul 05, 2021 10:29 am
Smaller carb rubber? bringing the carb closer to manifold?
I've also used a shorter manifold, can't remember where from? either Broady or Beedys
it all adds up bud
Re: Clearance
Postby vegansydney » Mon Jul 05, 2021 3:09 pm
These flange manifolds were made specifically for the Casa 185 to pull the carb closer to the engine and away from the panel, so they should be ideal for the Scootopia 185.
As an alternative, I've also adapted the BGM RT195/225 flange manifolds to fit small block inlet spacing. MB also makes a cast version, as opposed the BGM which is CNC.
vegansydney
Re: Clearance
Postby L111amo » Thu Oct 28, 2021 7:54 pm
Sorry for late reply, manifold from mb & all good, cheers boys
L111amo
Re: Clearance
Postby northernpete » Fri Oct 29, 2021 4:09 pm
Slightly off topic,but how does it run with the 28 carb.....looking to run similar with a 26...what exhaust is he running?
northernpete
Re: Clearance
Postby L111amo » Mon Dec 13, 2021 12:52 am
Runs great with a 42 clubman
L111amo
Re: Clearance
Postby northernpete » Fri Jan 07, 2022 4:54 pm
THANKS.....WHATS PERFORMANCE LIKE
northernpete
Return to Carburettors
Users browsing this forum: Bing [Bot] and 61 guests
