Series 3 22mm Jetex
Series 3 22mm Jetex
Postby gazzar15 » Mon Nov 02, 2020 8:14 pm
My Scootopia 22mm. Jetex seems to be not working...probably due to old fuel....my bad.Is there a recommended company that cleans them for Lambretta users ?
On the chance it may be knacked what would you use to replace it?
gazzar15
Re: Series 3 22mm Jetex
Postby Knowledge » Mon Nov 02, 2020 10:18 pm
Is the carb a true Jetex, or a Scootopia copy of the Dell’orto original?
Try buying an aerosol can of carb cleaner from Toolstation first. Strip the carb completely and give it a damn good blast with the carb cleaner.
Alternatively, carbs can be cleaned in a ultrasonic bath. Some scooter businesses offer this service but I don’t know which ones.
Postby bookertmgs1 » Tue Nov 03, 2020 9:35 am
If you have a quick google on ultrasonic cleaning - theres bound to be a local motorcycle shop / restorer near you that offers this service.
bookertmgs1
Postby Tractorman » Tue Nov 03, 2020 9:42 am
"not working" is a bit vague, are you sure its not the small hole in the pilot jet blocked?
Postby gazzar15 » Tue Nov 03, 2020 11:27 pm
Bought some carb cleaner earlier ....will be whipping the carb off at the weekend for a good clean.
BTW it is a scootopia jetex copy
gazzar15
Postby Rich Oswald » Wed Nov 04, 2020 2:05 pm
gazzar15 wrote:Bought some carb cleaner earlier ....will be whipping the carb off at the weekend for a good clean.
Do you not mean that it is a Scootopia Del Orto copy?
Postby gazzar15 » Wed Nov 04, 2020 4:13 pm
When I say not working I am meaning the scoot refuses to start it is sparking... but not firing up.
gazzar15
Postby Knowledge » Wed Nov 04, 2020 7:00 pm
Have you got good compression?
Postby gazzar15 » Wed Nov 04, 2020 10:21 pm
Yes good compression....
gazzar15
Postby HxPaul » Thu Nov 05, 2020 9:42 am
I had a Scootopia 22 mm carb and the float was catching on the inside of the float chamber.I bought an original Dellorto float (it was a little bit smaller)and the carb worked ok.
Postby gazzar15 » Thu Nov 05, 2020 10:46 am
thanks...where do I get one of those ?
gazzar15
Postby Rich Oswald » Thu Nov 05, 2020 12:11 pm
gazzar15 wrote:thanks...where do I get one of those ?
https://www.dellorto.co.uk/
Postby Storkfoot » Thu Nov 05, 2020 12:14 pm
They are readily available from most Lambretta dealers and Eurocarb. However, don’t go and buy one yet. When you strip the carb, look for witness marks on the float and float chamber. That should tell you if it is catching on the float chamber. If it is, gently file it so it doesn’t.
Also:
Check that your choke is operating correctly ie that it seals when not in operation and properly lifts when you pull it.
Check that your slide is letting air in whilst the throttle is at rest.
Personally, I like to check that the float needle is working too. Fit the carb without the float chamber. Gently support the float with your finger and then turn on the petrol tap. By gently moving your finger up and down you should be able to get a sense about whether the float needle stops the fuel entering the float chamber when the float is raised.
Postby gazzar15 » Fri Nov 06, 2020 11:29 am
Sorry gents it is the DellOrto copy
gazzar15
Postby Storkfoot » Fri Nov 06, 2020 1:15 pm
gazzar15 wrote:Sorry gents it is the DellOrto copy
Yes, that is correct. Jetex are Indian copies of Dell’Orto SH carburettors. They have been making them for many years but sometimes they are a bit hit and miss as to whether they work correctly out of the box.
Scootopia are a UK based business who gets parts manufactured for Lambrettas. Two or three years ago, they started retailing copy SH Dell’Ortos too. I don’t know where they are manufactured.
None of this alters anything though as you can use correct Dell’Orto jets, atomisers and slides in both Scootopia and Jetex SH carbs.
Postby gazzar15 » Sat Nov 21, 2020 10:53 pm
Got the carb off after a bit of trouble but managed to do it without damaging anything....Question for those in the know...should the slide be slightly open with the throttle closed ? Mine is...I might add that other than disconnecting the cables I haven’t any further work to strip it down.
gazzar15
Postby Storkfoot » Sun Nov 22, 2020 12:00 am
gazzar15 wrote:Got the carb off after a bit of trouble but managed to do it without damaging anything....Question for those in the know...should the slide be slightly open with the throttle closed ? Mine is...I might add that other than disconnecting the cables I haven’t any further work to strip it down.
Yes it should. To have ignition, you need petrol and air. If the slide was completely closed, you would not have any air getting through as you try and start the scooter with the throttle closed n
Postby gazzar15 » Sun Nov 22, 2020 9:20 am
Thanks will get going cleaning it up later...
gazzar15
Return to Carburettors
Users browsing this forum: Bing [Bot] and 61 guests
