Main Jet question
Main Jet question
Postby datpat64 » Sat Oct 19, 2019 5:04 pm
I've just changed from a BGM Exhaust to a Franspped Tourer on a S3 with a TS 1.
Bike running well without changing and Jets (tick over and air slightly adjusted but no new jets).
Done a couple of plug chops today and it's running quite lean, so what main Jet do people think? Does anyone have same set up and can let me know their jetting? Bike itself is running really well through all gears and low and high revs, just worried it's bait lean and off to Southport next Friday so don't need potential issues
Dave
datpat64
Re: Main Jet question
Postby Norrie Bodge » Sat Oct 19, 2019 8:15 pm
Which carb you using ?
Norrie Bodge
Postby ULC Soulagent » Mon Oct 21, 2019 8:41 am
And why do riders think that a change of main jet will cure all problems :?
ULC Soulagent
Postby bookertmgs1 » Tue Oct 22, 2019 2:02 pm
where in the range is it lean with the plug chops ?
1/4, 1/2, 3/4 , full knacker
that would indicate which setting you kneed to look at.
What carb & current jets are you using
as other people have indicated - changing main jet is useless if its lean at 1/2 throttle
bookertmgs1
Postby datpat64 » Mon Nov 18, 2019 8:39 pm
All sorted. Did full throttle plug chops and looked good so we're off and running without any changes
datpat64
Postby Scooterdude » Mon Nov 18, 2019 9:03 pm
datpat64 wrote:All sorted. Did full throttle plug chops and looked good so we're off and running without any changes
Just full throttle? Or did you do throughout the whole range as advised above? :?
Scooterdude
Return to Carburettors
Users browsing this forum: Bing [Bot], Google [Bot] and 42 guests
