Images chopped
Not for scooter questions!
Post your question if you need any help with using the forums and how they work.
Images chopped
Postby Les McLean » Mon Jun 16, 2014 4:14 pm
When I post images to the forum, I use 'Insert image' command from above, and I can view them OK on my desktop PC, but viewing on my iPad, the images are chopped (so you can only see the left half of the image)
In this post, someone else mentioned the images are 'chopped'
viewtopic.php?f=19&t=365" onclick="window.open(this.href);return false;
The reason I use the 'insert image' rather than 'upload attachment' is that I can post them directly from my web host, rather than taking up LCGB server space.
Les McLean
Re: Images chopped
Postby Knowledge » Mon Jun 16, 2014 7:50 pm
This might be a viewing issue with the iPad. All images on the forum I view through the iPad are chopped, often to the near eradication of the scooter in the photo.
I keep meaning to compare images on my iPad and my laptop to see if my assumption is correct, but then life gets in the way.
Return to Forum Help
Users browsing this forum: No registered users and 10 guests
