Wide wheel rims / tyre size...?
Postby Andy B.L.C. » Fri Sep 23, 2016 10:05 pm
Not doubting the source of the info, but would using a 100 x 90 x 10 on a standard rim =ish a 350 x 10 on a wide rim...?
Andy B.L.C.
Re: Wide wheel rims / tyre size...?
Postby martyn dwane » Thu Oct 06, 2016 4:26 pm
i use a 100/90 x 10 on standard width rims.
cant quite understand your question.
martyn dwane
Postby rossclark » Fri Oct 07, 2016 1:01 pm
100/90 x 10 on a standard rim is very slightly 'taller' and wider than than a 3.50 x 10 on the standard rim.
I'd imagine that a 3.50 x 10 on a wide rim would have a lower profile than the 100/90 on a standard one.
Postby Andy B.L.C. » Fri Oct 07, 2016 10:59 pm
Cheerz Ross! That was the answer that I was getting at, the numbers made no sense to me but 'wider' & 'taller' (as long as not the 400x10 bump stop dumped, no problems in a 75mph blow out Margate '88 scenario, square section steel mesh thing...) were what I in my ignorance was looking into, specifically the wider bit...
Andy B.L.C.
Postby rossclark » Sat Oct 08, 2016 7:36 pm
The metric sizes are quite hard to get your head round.
100 means it's 100 mm wide which is more or less 4"
90 is the aspect ratio, so 90% of 100 mm therefore 90 mm tall which is slightly more than 3.5".
100/90 usually go on the rear with no issues with standard rims.
Postby Andy B.L.C. » Sun Oct 16, 2016 5:29 pm
danx!, makes sense now ;)
Andy B.L.C.
