Gp side casing
Gp side casing
Postby knygall » Tue Aug 18, 2015 5:21 pm
I have a series 2 crankcase in good condition and would like to up grade the clutch and crank,.. I know gp crank is not a problem but not sure if gp chain case will fit the series 2 crankcase??,.. I'm planning on 5 plate style and new crownwheel etc as I currently run in my gp,..and want similar in my series 2....thanks for any advice.
knygall
Re: Gp side casing
Postby Wack » Tue Aug 18, 2015 5:46 pm
Yes you can use the GP casing, it's stronger around the kickstart boss if used in a tuned motor. If you're fitting it in a Ser 2 frame you will need a wider cranked kickstart pedal, Spaq make them and Beedspeed etc sell them
Re: Gp side casing
Postby knygall » Tue Aug 18, 2015 6:56 pm
Cheers wack,.. Just the info I needed
knygall
