SIP Speedo fault
SIP Speedo fault
Postby michaeltv2000 » Tue May 05, 2015 8:57 pm
My sip speedometer has been working fine for the last 200 miles but 30 miles ago the speedo started reading 15mph under according to the
rev counter.So when the counter was reading 6500rpm the speedo was reading 50mph. Has anybody any ideas why? Mike
michaeltv2000
Re: SIP Speedo fault
Postby Wack » Wed May 06, 2015 5:38 pm
Where's it getting the reading from, cable or sensor?
Postby michaeltv2000 » Fri May 08, 2015 11:04 am
Cable
michaeltv2000
Postby michaeltv2000 » Tue Dec 08, 2015 5:36 pm
Problem solved by fitting another worm drive and the hub drive.
michaeltv2000
