S2 Side panel handle mounts
PostPosted: Tue Apr 07, 2015 11:25 pm
by sprog58
The spot welded plates that hold the tube through which the handle mechanism passes at the back of the side panels are rusted through. Does anyone know of a manufacturer that sells these separately? They are quite complex to re-form from scratch.
Re: S2 Side panel handle mounts
PostPosted: Wed Apr 08, 2015 12:36 pm
by Knowledge
Hmm. I've never seen these for sale, but is the tube for the panel mounts still in good order? If so, then why not make the best of what you have got, either by inserting some extra steel to support the tube, or adding some alternative strengthening material like fibre glass. It isn't going to show.
Oh, and welcome to the fourm.
PostPosted: Sun Apr 12, 2015 7:36 pm
by sprog58
Thanks, the alternative will be to cobble somthing together that looks like the much more simply designed Series 3 mounts, which appears to be an angled strip of steel.
