hydraulic rear brake
PostPosted: Wed May 22, 2024 12:46 pm
by eaststandjohn
Hi there
I was wondering has anyone fitted an hydraulic rear brake? As i've had a quick look at them as ive been looking for parts for my front 1 and ive noticed there's 2 different types ie the oiltech external disc type and the tino type that still use interal shoes
does anyone have any thoughts please?
Re: hydraulic rear brake
PostPosted: Thu May 23, 2024 3:35 pm
by Fast n Furious
Personally, I fail to see the point in them.
The original gear is perfectly satisfactory if set up and maintained properly.
PostPosted: Thu May 23, 2024 4:08 pm
by Storkfoot
Did Oiltek ever put the rear hydraulic set up into production?
As for Tino’s internal Hydra rear set up, I am unsure whether I have ever seen that for sale, let alone heard of anyone who has one fitted.
With the rear set up, I can’t see beyond the hassle of even taking a wheel off, never mind setting it up properly.
PostPosted: Sat May 25, 2024 1:04 pm
by gizmo
Fast n Furious wrote:Personally, I fail to see the point in them.
+1
PostPosted: Sun May 26, 2024 8:57 am
by Rich Oswald
+1
+2
PostPosted: Sun May 26, 2024 7:25 pm
by tim_mason
i have had three scooters with rear discs and like anything else its a learning curve with setting them up ,but worth it in the end and look trick when fitted.
PostPosted: Wed May 29, 2024 10:13 am
by eaststandjohn
Storkfoot wrote:Did Oiltek ever put the rear hydraulic set up into production?
Im not sure if they did thats why i was asking thank you
PostPosted: Wed May 29, 2024 10:16 am
by eaststandjohn
tim_mason wrote:i have had three scooters with rear discs and like anything else its a learning curve with setting them up ,but worth it in the end and look trick when fitted.
were they shop bought or home made tim ?
PostPosted: Wed May 29, 2024 12:40 pm
by gizmo
I'm sure Oiltek did produce them. I remember one being on display on their shop counter many moons ago. They looked good. I'm sure if you really wanted one Paul at Oiltek would do you one.
PostPosted: Wed May 29, 2024 2:44 pm
by eaststandjohn
gizmo wrote:I'm sure Oiltek did produce them. I remember one being on display on their shop counter many moons ago. They looked good. I'm sure if you really wanted one Paul at Oiltek would do you one.
thank you ill bear it in mind, i dont want to bother him just yet as ive not made my mind up yet
PostPosted: Wed May 29, 2024 6:00 pm
by tim_mason
The ones i have used are the early type from Pat in Saigon , these came with an indian made 'RAMP' rear hub which lasted about 400 miles second one lasted the same , so i machined a good quality hub , sorted. Second one i binned the foot brake bracket and welded a bracket to the frame , much neater ,
I am fitting the same to a side project but with a rear set brake pedal with the slave cylinder fitted to the back plate .
PostPosted: Wed Jun 05, 2024 9:43 am
by eaststandjohn
Now there's a thought thank you tim, how are you going to fit the caliper though?
PostPosted: Fri Jun 07, 2024 3:47 pm
by tim_mason
I have another second hand kit i am wiling to let go if you are serious about fitting one ,
i will send you my phone number by PM if you are wanting to buy a brake ,
Cheers Tim.
