Speedo inner cables
Speedo inner cables
Postby Andy B.L.C. » Wed Apr 12, 2023 1:57 pm
While Italian & Indian cables have different size ends, are all Italian Ser1 - 3 inners interchangeable? Need to replace the Ser1 inner. Many thanks in advance!
Andy B.L.C.
Re: Speedo inner cables
Postby Storkfoot » Wed Apr 12, 2023 2:39 pm
I think all Italian speedo inners up to, maybe, early ‘63 are the thinner ended type. Very early Series 3 had the thinner ones ended cables.
Postby tim_mason » Mon May 15, 2023 9:42 pm
if i was you i would change the complete cable ,Outer and inner as i have found different cable diameters also i sell Smiths cables for original chronometric speedos and tachos
and a fair few of cables that originate from the far east the drive /top end is made wrong and when you tighten the knurled nut to secure the cable it pushes the drive spindle into the movement,
and then it costs a lot of money to repair the clock ,
So buy and fit a new matching cable,inner and outer,
tim_mason
