Marrsy7 wrote:Hi all I’m just on fitting a hydraulic front disc brake to my gp and the original spindle nuts don’t fit anybody know wot size nut and thread I will need to buy ? Cheers
dickie wrote:Marrsy7 wrote:Hi all I’m just on fitting a hydraulic front disc brake to my gp and the original spindle nuts don’t fit anybody know wot size nut and thread I will need to buy ? Cheers
I've just had this problem on 2 hubs from different suppliers.
The thread should be 12 x 1.5mm and both mine were as were the nuts I had.
However, the threads on the spindle and the nuts were badly cut. I tried nuts from different suppliers and some were better than others. I found stainless were worst.
So I bought a die nut and tap. The die nut would not go down the spindle as it was so bad that my vice (not the best vice around) would not hold the spindle. But I improved the nuts with the tap enough that I could get them.onto the spindle. Still a little tight but ok.
Which hub have you got?
hullygully wrote:be careful as they're a fine thread
Users browsing this forum: No registered users and 26 guests
