Kill button
Kill button
Postby Mick1499 » Sun Mar 08, 2020 7:05 pm
Hi all. Started scoot after full restoration, would start then wouldn’t, turns out if I remove the kill wire
It would start, when kill wire is replaced it would die (that is replacing the wire only, not pressing button).
Confused why it started with the wire in place at all. As far as I can tell, the wire is going in correct hole in bulb holder.
Mick1499
Re: Kill button
Postby coaster » Sun Mar 08, 2020 8:23 pm
Mick1499 wrote:Hi all. Started scoot after full restoration, would start then wouldn’t, turns out if I remove the kill wire
That would suggest that your kill button is stuck in, simple to test if you have a muli-meter or a battery, a lamp and some wire
Re: Kill button
Postby Mick1499 » Sun Mar 08, 2020 8:50 pm
Button fells like its going in and out ok will remove and check many thanks
Mick1499
Re: Kill button
Postby Fast n Furious » Mon Mar 09, 2020 12:46 am
Try squirting some WD40 into it before writing it off.
Re: Kill button
Postby St George » Mon Mar 09, 2020 7:08 pm
Could have a break in the insulation of that wire earthing out. Yes a tester will work, I have one on Ebay. :lol:
St George
