Order of things i need to do to register
Postby dave999 » Wed Nov 27, 2019 6:11 pm
Have read many of your stories in this section of the board in respect to DVLA and registration...
most of you have NOVA certs or an old log book and i don't. this worries me
just wanted feedback on my plan
i have 2 lambrettas purchased a long time ago. Both dismantled. neither is likely, although i can't be sure, to have had a UK reg ever or at least since it all got computerised.
One is an Eibar LI 125 Series 3, a model never sold here, made between 66 and 73 (its a spanish built italian scooter, the only spanishness is the engine mount gusseting all the rest like an italian scoot) it is complete with original engine, and all parts, but its all in boxes
One is a 1965 TV175 that i have most of i.e frame forks engine headset + most bolt on body bits and parts.... its also in boxes engine number is about 100 out from frame so pretty sure its not original but not the wrong year
I have no paperwork for either
the LI is likely to be an import but i did not import it and it was not sold to me as an import
the TV could be a UK bike or an Import
do i build and restore and then try to register
or try to register first
current plan
1) frame and engine and parts photos into LCGB and potentially perry lewis to get date letters
2) letter + v112 and V55/5 and see how we go. SORN both until built
3) hope nobody wants to come and see them
Other plan
plough £1000s into both over the next few years and try to register them when done.
potentially risking not 1 but 2 white elephants that can not be registered or are flagged as ringers
i'm inclined to go with option 1 and cross my fingers.....
the receipt i got from the seller is long gone and was worthless anyway 2x lambretta sold as seen etc.
easy to procrastinate when you cant see a sensible route forward
Any tips ?
Dave
dave999
Re: Order of things i need to do to register
Postby Toddy » Thu Nov 28, 2019 7:03 am
There will be people along giving you their advice as a few on here have been through it .
You will neeed to build both scooters to register them as you will more than likely need an inspection to register or if your lucky you may not , you dont need to spend thousands just put them together so they look like a complete scooter , dont need to start or have lights
You will need to go down the v55/5 route and you will require NOVA docs to register both if you have no relevant info on the one you think may be UK registered by relevant info i mean original V5 as that is usually what DVLA require unless you can obtain a document from the local goverment office where the scooter was registerd which has the frame number on
All the info you need for Dating letter application is on our website (Link below)
http://www.ilambretta.co.uk/register.html
Im sure ive missed something :lol:
Hope this helps
Postby Rich Oswald » Thu Nov 28, 2019 2:01 pm
Couple of things to add to what Paul Todd has said above:-
Please do not contact Perry Lewis direct, I will do that for you.
Never ever mention a box of bits to DVLA!!
A large percentage are being inspected now especially ones which are MOT exempt so chancing they won't get inspected is a bad idea. Build them first either restored or unrestored.
Any other questions PM me, ring me or email me.
Richard Oswald
LCGB Registrar
Postby dave999 » Thu Nov 28, 2019 5:28 pm
advice noted gents
many thanks
i'll be in touch when i have mined then out of the pit i call a garage
Dave
dave999
Postby aby » Thu Feb 13, 2020 11:42 pm
The process takes about 4 months, if all is in order, I was refused a registration at first as they said my scoot was not ride able from the photos sent in.
From memory the nova part is the easiest, my scoot was an Italian import so just got a dating letter filled in the forms and sent frame and engine rubbings.
I never had an inspection when i resubmitted (a different inspector signed it off)
So in your case I would get it looking finished before sending photos, I was helped in the process from a guy online who even helped type cover letters for me when needed.
If I can find his blog I will post it here
aby
Postby Rich Oswald » Fri Feb 14, 2020 10:46 am
aby wrote:The process takes about 4 months, if all is in order, I was refused a registration at first as they said my scoot was not ride able from the photos sent in.
Sorry but I disagree. If all is in order it takes two weeks and if an inspection is required then three to four weeks.
Postby rossclark » Fri Feb 14, 2020 12:48 pm
When I did mine I found that getting it MOTd resulted in it not getting inspected and when I sent in the paperwork I got my number back in about 10 days.
My assumption here is that the MOT confirmed that it was a complete and roadworthy vehicle and that the numbers matched the documents as it was MOTd on the frame number, and that this means no need for another inspection.
Postby bookertmgs1 » Mon Feb 17, 2020 12:05 am
My last one took 2 weeks over Xmas - so less than 10 working days
No MOT submitted and no inspection required. Previous two had been MOT'd on frame number.
NOVA can be done online (and therefore get a NOVA number immediately) with a little imagination and creative thinking - otherwise just send for the form and wait for the number to come back.
bookertmgs1
