DL125 TURQUOISE
DL125 TURQUOISE
Postby Covboy » Tue Feb 02, 2016 5:43 pm
Hi
Here are some pics of a 1971 dl 125 I collected at the weekend.
Already blasted and painted to a good standard.
I've ordered all the bits I need to finish it off so it should be a nice straight forward assembly job ( those words will come back to haunt me I'm sure!)
Forks hub and stand etc powder coated silver.
New zinc plated tank ordered - the one it came with looks nice on the outside but very rusty inside.
Re: DL125 TURQUOISE
Postby Afandy » Tue Feb 02, 2016 7:14 pm
Very nice .....I had a brand new one in 1971 ....this colour ...was yours a British scoot?
Afandy
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Tue Feb 02, 2016 7:23 pm
Very nice Steve. Paintwork looks good.
What's the plan for the motor?
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby Covboy » Tue Feb 02, 2016 7:35 pm
It's an Italian import. Already registered with the dvla -J reg
Re the engine... Not sure yet! It came with a 125 unit , 12 electronic ignition but no top end. I've got a 150 barrel and piston from my li that I was thinking about putting on just to see what the motor is like.
Re: DL125 TURQUOISE
Postby Toddy » Tue Feb 02, 2016 8:39 pm
Very nice That , I like a turquoise GP :D
Re: DL125 TURQUOISE
Postby Covboy » Sat Feb 13, 2016 5:37 pm
This is the engine that came with the scoot. I've cleaned it up and put a standard 150 top end on it that I had lying around. Fingers crossed I'm hoping that it will all run ok. If it does I'll treat it to a kit!
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Sun Feb 14, 2016 10:45 am
Looks a clean motor Steve. Is it the original motor then?
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby Covboy » Sun Feb 14, 2016 1:20 pm
Hi kris
Original motor... The casing has been chromed at some point. Cleaned up well with "Jizer"
Last few parts should be arriving this week so hopefull it will be running and MOT'd by March
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Sun Feb 14, 2016 1:59 pm
Nice!!
Mine isn't as clean as I hoped so it's a bit more of a rusteration project than I thought.
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby Covboy » Sun Feb 14, 2016 6:08 pm
Hi kris - can you post some pics?
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Sun Feb 14, 2016 8:36 pm
I will try and take some pics Tuesday hopefully it will be registered by then.
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby Covboy » Sat Mar 12, 2016 11:52 am
Coming together nicely now . Plan to start it up this weekend. The condition of the engine is an unknown to me. I put the top end on but decided to try it first rather than strip it down and ending up replacing everything! Got s nice seat on order from RLC, should arrive any day now.
Re: DL125 TURQUOISE
Postby Warkton Tornado No.1 » Sat Mar 12, 2016 1:13 pm
Good Luck with starting up!
Don't forget that your tank is full of crap. It may be worth removing the tank filter & using just an inline filter initially.......Having said that, I run my SX like that all the time! Easier to dump any sh1te!
Re: DL125 TURQUOISE
Postby Covboy » Sat Mar 12, 2016 2:40 pm
Thanks....it's a brand new scootopia zinc plated tank...should be ok...!
Re: DL125 TURQUOISE
Postby Covboy » Sat Mar 12, 2016 5:38 pm
Update : good compression but no spark. New regulator and CDI.
Run out of time for faulting this weekend.
And yes the ignition was on ... I've made that mistake several times !
Re: DL125 TURQUOISE
Postby Covboy » Sat Mar 12, 2016 6:11 pm
Update#2
Tested the wires from the stator - short circuit between the white and brown (red) wire.
Lesson learned - I should have tested it when it was on the bench rather than in the scoot.
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Sat Mar 12, 2016 6:23 pm
Looks great Steve.
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby Warkton Tornado No.1 » Sat Mar 12, 2016 6:48 pm
Sorry. I thought that:
still applied!
I bet you can't leave the bike 'so near so far' & try again tonight!
Re: DL125 TURQUOISE
Postby Kristof Lammy pie » Sat Mar 12, 2016 8:11 pm
Are they standard rims Steve?
Kristof Lammy pie
Re: DL125 TURQUOISE
Postby ToBoldlyGo » Sat Mar 12, 2016 10:47 pm
Look like SIP rims to me.
Nice scooter. I'm intrigued by this seat you're getting from RLC. Be interesting to see.
