My Lis 125
My Lis 125
Postby Kristof Lammy pie » Sun Jan 31, 2016 7:18 pm
Newly acquired lis125 1968 plastic toolbox push in fork rubbers and square badge.
Kristof Lammy pie
Re: My Lis 125
Postby Covboy » Sun Jan 31, 2016 7:24 pm
Nice - love the colour. How does it go?
Re: My Lis 125
Postby Kristof Lammy pie » Sun Jan 31, 2016 7:39 pm
Not great at the moment, it's not a great starter and the exhaust is leaking badly from the manifold.
But I spent all day today sorting the cables, clutch and brakes.
Tomorrow I've got to do the carb and fuel.
The steering is rubbing somewhere and the front wheel is leaning badly which I need to look at. I presume it's bearings gone or the forks. I've never touched forks before so should be fun.
Lots to do but I love it.
Kristof Lammy pie
Re: My Lis 125
Postby roli150lam » Sun Jan 31, 2016 8:48 pm
Nice.
roli150lam
Re: My Lis 125
Postby HxPaul » Sun Jan 31, 2016 8:53 pm
[quote="Kristof Lammy pie"]Not great at the moment, it's not a great starter and the exhaust is leaking badly from the manifold.
Lots to do but I love it.[/quote
It could be the bottom buffer on one side,also with the steering rubbing,check to see if the bottom of the headset is rubbing on the horncast.
Re: My Lis 125
Postby Kristof Lammy pie » Sun Jan 31, 2016 9:05 pm
Thanks Paul.
Thought it may be a buffer.
With regards to the headset. It was very loose so tightened the bearings up to stop the play but I thought I had done it just enough to avoid any notchyness.
I have noticed the Horncast is marked on the front underneath bottom of the light casting. Is that what you mean? Just wondered how I can stop that?
Ta
Kris
Kristof Lammy pie
Re: My Lis 125
Postby Kristof Lammy pie » Sun Jan 31, 2016 9:17 pm
I've just gone out and had a look at it and it's the very top of the legshield thats rubbing against the headset.
I take it there's not much that can be done about that?
Kristof Lammy pie
Re: My Lis 125
Postby HxPaul » Sun Jan 31, 2016 9:24 pm
I had the same thing with my SX,what I did was sand the top of the horncast with emery paper.I'm not saying that was the right thing to do,but thats what I did.First you need to replace the fork bearings,that may be enough to move the headset forward and stop it from rubbing on the headset.
Re: My Lis 125
Postby HxPaul » Sun Jan 31, 2016 9:30 pm
Are you sure its rubbing on the legshields,because the headset doesn't come near the legshields,its more likely to be rubbing on the chrome ring.If this is the case its an easy fix,all you need to do is unfasten the headset clamp pinch bolt and lift the headset a bit so it clears the chrome ring.I've just noticed that the scooter is a late model and as such it doesn't have a chrome ring.Your diagnosis could well be correct and the bottom of the headset could be rubbing on the legshields,either way the fix is the same ie.unfastening the clamp pinchbolt and lifting the headset a bit.
Re: My Lis 125
Postby Warkton Tornado No.1 » Sun Jan 31, 2016 9:37 pm
Whoah! Before you start rubbing down…….
The horncasting can be adjusted by virtue of the legshield bracket bolting to the frame. For instance, if you wanted to move the horncasting toward the back of the bike, you need to (obviously) remove it & ‘tweak’ the legshield bracket by bending its ears forwards. It’s amazing what difference it can make to the top end where the horncasting gets close to the headset. Also, paint thicknesses affect the fit so some might need scraping off. I’ve even seen the drastic measure of the legshield bracket being persuaded to be on the other side! Not by me, I might add…
Conversely, washers can pack the legshields/horncasting forward.
I hope this helps…
Re: My Lis 125
Postby Warkton Tornado No.1 » Sun Jan 31, 2016 9:44 pm
Ooops!
I meant to say. Lovely bike, BTW!
I wonder how many combinations there must be of 'run out' changes with toolboxes, square badges, fork buffer fixing & side panel attachment.
I believe that many late Innocenti Lambrettas may have been assembled without accurate records as to what was used or even where assembly may have been, but I'm probably out of my depth on that!
Re: My Lis 125
Postby HxPaul » Sun Jan 31, 2016 9:57 pm
Warkton Tornado No.1 wrote:Whoah! Before you start rubbing down…….
I hope this helps…
You'll notice that when I said I used emery cloth to rub the top of the horncast down,I didn't say thats what he should do,just thats what I did.
Re: My Lis 125
Postby davla » Sun Jan 31, 2016 11:12 pm
Very nice....
davla
Re: My Lis 125
Postby Kristof Lammy pie » Sun Jan 31, 2016 11:12 pm
I will take the headset off and see if it can be tweaked slightly.
Cheers guys.
Kris
Kristof Lammy pie
Re: My Lis 125
Postby HxPaul » Sun Jan 31, 2016 11:26 pm
Kristof Lammy pie wrote:I will take the headset off and see if it can be tweaked slightly.
Cheers guys.
Kris
No need to remove it,just slacken the pinchbolt and lift the headset just a little.
Re: My Lis 125
Postby Warkton Tornado No.1 » Mon Feb 01, 2016 1:11 am
You are quite right & in my haste & choice of words it could look like I was implying that you were advocating to do the same. Which, of course you weren't. :oops:
My apologies to you Paul, as we are all trying to help, I know.
Re: My Lis 125
Postby HxPaul » Mon Feb 01, 2016 10:28 am
Re: My Lis 125
Postby johnnyXS » Mon Feb 01, 2016 11:26 am
nice pair :D I particularly like the colour scheme on your TV.
So you're a roadie eh ! ;) exquisite Tommasini
johnnyXS
Re: My Lis 125
Postby Kristof Lammy pie » Mon Feb 01, 2016 8:04 pm
johnnyXS wrote:nice pair :D I particularly like the colour scheme on your TV.
Yes lol.
Colnago, Bianchi Cinelli and Tommasini the Italys best.
Kristof Lammy pie
Re: My Lis 125
Postby johnnyXS » Mon Feb 01, 2016 11:35 pm
blimey you've got some nice toys ! :D
johnnyXS
