Muggy powered '62 Li3
Postby Matty73 » Fri Jul 10, 2015 10:28 pm
Matty73
Re: Muggy powered '62 Li3
Postby shane BBoys » Sat Jul 11, 2015 4:13 pm
Very nice. I used to have the 186 on my old LI Spanish
The 1st time was 45 mark 1 with a porcupine head & it
Was fast as, till the carb came loose and she bloo.
I then had a mark 4 with the dowels etc but never
Liked that, sold it on to fund latest project( see jet set)
Cheers Shane,
shane BBoys
Postby Covboy » Sat Jul 11, 2015 4:44 pm
Very nice indeed
8-)
Postby Toddy » Mon Jul 13, 2015 6:05 am
Nice Job :D
Postby Matty73 » Mon Jul 13, 2015 9:35 am
shane BBoys wrote:Very nice. I used to have the 186 on my old LI Spanish
Cheers Shane,
Cheers, It's the 198 with 26mm phbh, varitronic & ancillotti. Not the fastest scoot in the world but goes well enough for my liking. Not really fully caned it yet.
Matty73
Postby dave411 » Mon Jul 13, 2015 5:05 pm
:D hurrah,finally found someone withe the same set up thatI will be using.
Are you using the Li 150 gearbox?Also,what spec jetting are you using?The carb I have hasnust got whatever jets it came out of the factory with,so I am sure they will need changing.Just looking for a starting point really.
dave411
Postby Matty73 » Tue Jul 14, 2015 9:14 am
dave411 wrote::D hurrah,finally found someone withe the same set up thatI will be using.
Hi, it is a 150 gearbox. Carb settings (set up by camlam) are;
106 main
AV266
53 pilot
50 starter
X7 needle
Air screw about 1 1/2 turns
Note that it's through a breathe sweet filter.
Matty73
Postby dave411 » Tue Jul 14, 2015 2:52 pm
Yep,me too.
dave411
