And? What's it like to ride!
Paul
https://ilambretta.co.uk/forum/
It just feels like a very effective but smooth cable operated brake, ( a good positive feel to the lever), I feel sometimes a hydraulic disc can feel a bit harsh, this cable one isn't by any means..Afandy wrote:is that rust down the middle of the legshields? No its a mixture of glue and foam, I think some form of gauges were once mounted there..
...Also has that got the uprated front disc? If so any better?
lambypolo wrote:Did anyone manage to talk Dean into taking a mould off that legshiled toolbox while it was off?
Toddy wrote:Well done Tim , did you get a go on the Vespa?
Tim_Craig wrote:
I believe a mould has been taken, best looking/fitting toolbox Iv'e seen to be honest.
Afandy wrote:Lucky man ......is that rust down the middle of the legshields? ...Also has that got the uprated front disc? If so any better?
xenia1 wrote:Had a look over this in detail and looked very much like something about to go into production. Usually prototypes will have various unfinished/handmade parts but even the cowlings looked pressed. Easily the most interesting machine at Bridlington. Very lucky to have a blast on it Craig
Ps- the brown foam looked as if something had been laid on the legshields for a very long time and also had a glue like substance on the toolbox door.
The blue on the engine casing is engineers blue.
Rich Oswald wrote:xenia1 wrote:Had a look over this in detail and looked very much like something about to go into production. Usually prototypes will have various unfinished/handmade parts but even the cowlings looked pressed. Easily the most interesting machine at Bridlington. Very lucky to have a blast on it Craig
I thought maybe an inline spare wheel had been stuck in there at some time maybe prior to the legshield toolbox???
Storkfoot wrote:Did either of the twin prototypes have side panels?
