GP150 lockdown project
Postby Storkfoot » Wed Aug 26, 2020 5:45 pm
I have a couple of projects on the go, a Vega and an SX150. I had also acquired a few reasonably priced GP150 parts and already had an engine to go in it.
So, I had a lockdown project but, first of all, I face a couple of challenges related to the leggies and forks.
Re: GP150 lockdown project
Postby Toddy » Thu Aug 27, 2020 6:09 am
That will keep you busy Paul ;)
Postby dickie » Thu Aug 27, 2020 6:12 am
At the risk of looking stupid, what's wrong with the forks?
Postby Storkfoot » Thu Aug 27, 2020 8:21 am
dickie wrote:At the risk of looking stupid, what's wrong with the forks?
The witness marks on the stem are indicative of them being bent. Placing a set square against them quickly confirmed that.
They have been straightened now.
Postby Storkfoot » Thu Aug 27, 2020 8:27 am
Toddy wrote:That will keep you busy Paul ;)
Thankfully, the frame is in better condition than the legshields (they came from separate scooters). Also thankfully, I know a good fabricator and welder (Just as well, you think :D ) but he is dead busy with other work at the moment.
Postby jonw » Fri Aug 28, 2020 7:51 am
I've often wondered how safe this is?
The forks have been bent one way and then bent back, hasn't their integrity been compromised and weakened?
jonw
Postby Storkfoot » Fri Aug 28, 2020 8:28 am
I see where you are coming from, same principle as bending a fork to and fro. Hopefully, it’d have to be bent a long way and multiple times before it got into the realms of fracturing. But, I am no expert.
Postby dickie » Fri Aug 28, 2020 10:11 am
Storkfoot wrote:I see where you are coming from, same principle as bending a fork to and fro. Hopefully, it’d have to be bent a long way and multiple times before it got into the realms of fracturing. But, I am no expert.
You're right. It isn't a big deal. Especially if heat is used in the straightening process. That said, you'd be hard pushed to straighten them without heat.
Postby Warkton Tornado No.1 » Sun Aug 30, 2020 11:50 am
Steel is a very good durable material & the forks are flexing all the time throughout their life. They won't work harden & crack in even extreme use.
They are normally straightened via the use of an hydraulic press, though a fly press can be used. With respect, heat is not required via the process that I am aware of. But that could just be 'me!' :D
Yet to use heat with engine mounts, either, & I've done a few! It's all about overcoming friction & if you use deep groove ball bearings in a number of sizes (preferably thrust or taper bearings, but I don't have any!) they go in & out a treat....Oooer! I have oxy-acetylene but avoid heat getting near rubber mounts like the plague. Or Covid 19....
Postby coaster » Mon Aug 31, 2020 2:40 pm
I worked for a while in a large motorcycle dealership when I left school and straightening fork legs was a regular job for one of the mechanics as he was a big lad. He used a scaffold pole and bench vice to do the straigtening and a surface plate, V blocks and a dial gague , no heat.......that said, Lambretta forks went straight in the scrap bin as did frames and even slightly damaged panel work :shock:
Postby dickie » Tue Sep 01, 2020 8:54 am
Gents, you're correct. For the small amount of bending needed there, heat isn't required.
Unless it's been bent a long way or a short amount, many times bending cold is fine.
I should add that although I work in heavy engineering, I'm a control and electrical engineer so I'm around this kind of thing but it isn't actually my area of expertise. So I can't really comment with complete authority.
Postby Warkton Tornado No.1 » Tue Sep 01, 2020 1:30 pm
dickie wrote:Gents, you're correct. For the small amount of bending needed there, heat isn't required.
As an engineer, although I am mechanically biased & in general a designer, no doubt our outlooks are very similar. I don't think we ever stop learning in our thirst for knowledge, whilst trying not to forget first principles :D
Not wishing to get too far off topic, mechanical advantage, & how best to achieve it, is probably the main essence of our continued passion for Lambrettas & our enthusiasm for this Forum.
The example of extracting engine mounts, & the massive improvement in method by utilising bearings in the process to overcome thread friction needs to be tried to be believed. I must acknowledge Dave Webster (RIP) for advising me of that.
Similarly, the clutch mechanism has been shown to be improved by modification to rack & pinion. No doubt the Chiselspeed conversion is great & VFM, but my finances won't currently allow indulgence. However, I do have a motorcycle mechanism that I aim to adapt ;)
(I reiterate & apologise to Storkfoot & anybody else if I have hijacked this Post :oops: )
Postby Storkfoot » Tue Sep 01, 2020 2:55 pm
No problem at all. I put threads up on this forum for discussion and to try to keep it alive, given that it appears significantly quieter than it used to be.
Postby Storkfoot » Thu Oct 01, 2020 4:47 pm
A productive day straightening up a few dings, crossmembers and stabilising the rust inside the frame.
Postby Jeff t » Fri Oct 02, 2020 7:57 pm
Just started a refurb on an Li special what did you use to stabilise the frame?
Jeff t
Postby Storkfoot » Fri Oct 02, 2020 11:40 pm
Jeff t wrote:Just started a refurb on an Li special what did you use to stabilise the frame?
Diluted Rust Remover from Machine Mart. I just blocked the two drain holes under the frame, pumped it in and left it overnight. Ideally, you should pump in Waxoyl after blasting and painting, I suppose, but what I have done so far will not do any harm.
Heat and a ball pein hammer, followed by a little bit of welding to sort out the tears:
Postby Storkfoot » Fri Oct 09, 2020 2:02 pm
Welding back so dry build next
Postby gaz_powell » Fri Oct 09, 2020 7:34 pm
Another nice project on the go, Paul.
Postby Storkfoot » Fri Oct 09, 2020 9:40 pm
gaz_powell wrote:Another nice project on the go, Paul.
Gaz, My mate who saved the legshields with his welding abilities never wants to see Lambretta legshields again. I tried to reassure him that he had saved a bit of history. He wasn’t convinced :shock:
Postby bike grim » Sat Oct 10, 2020 1:44 pm
Looks a good job. I’ve just bought a new welder and want to have a go at some legshields so if anyone has an old set they want to donate to practice on let me know (and panels)
