Arrives tomorrow.....
Postby lammydave » Thu Jul 26, 2018 6:09 am
lammydave
Re: Arrives tomorrow.....
Postby shane BBoys » Thu Jul 26, 2018 6:26 am
that looks to be in great condition, any plans?
:mrgreen:
Shane.
shane BBoys
Postby lammydave » Thu Jul 26, 2018 4:19 pm
shane BBoys wrote:that looks to be in great condition, any plans?
:mrgreen:
Shane.
leave body as is...
RT195
30mm delly
Scootopia Ancillotti
new crank
electronic ignition with tambs stator and cdi
lammydave
Postby ToBoldlyGo » Thu Jul 26, 2018 6:05 pm
Nooooo.......... You don't want a 30mm carb.
Postby TurboTrev » Thu Jul 26, 2018 6:17 pm
Nice, not many very late SX150s about. 8-) Is it an import or UK from new?
TurboTrev
Postby Scooterslag » Thu Jul 26, 2018 6:56 pm
very nice late SX150 with the clip on panels and plastic butty box - good find fella , nice to see you keeping it as is 8-)
Postby citydaz » Thu Jul 26, 2018 11:10 pm
just add MB developments front dampers
citydaz
Postby Ranburetta » Thu Jul 26, 2018 11:42 pm
Marco has some nice scooters.
Ranburetta
Postby pacemaker » Fri Jul 27, 2018 9:36 pm
very nice Dave
pacemaker
Postby lammydave » Fri Jul 27, 2018 11:26 pm
to answer questions... it's an import bought from Marco at Scooter Emporium... a true gent and a good price for the scooter...
I don't have too much free time, so I'll get Rob Skipsey to do the reg for me
I'll be fitting front dampers, with billet brackets from lth...
At the moment it has a great spark on the existing points system, but I will be fitting a new crank with the rt kit ... can I still keep the points set up as the taper on the flywheel is different, so will need a new one??...
Keeping the front hub as is, (no disc brake atm) as long as I can get it working well... on a lambretta?? ...May be a tough job
when I fit the RT kit, i'll also fit all new bearings and seals as well as a new clutch
lammydave
Postby Warkton Tornado No.1 » Sat Jul 28, 2018 9:40 am
The stator may need the bore to be opened up, but should otherwise work with a GP crankshaft.
The most reliable scooter I ever owned was an unmolested GP 150 that I added 200 forks & a disc brake to along with a modified exhaust that we used to call 'straight through' though the tailpipe diameter was marginally increased.
You could do worse than try something similar for a while, as I would think it very likely that the similar barrel, preferably a 22 mm Dell'Orto & an unrestricted exhaust should comfortably enable a genuine 70 mph to be achieved just by allowing it to rev on. From what I read on here, many spend a fortune & hardly achieve that...
IMHO, tuning begins with optimising what you have.
Money saved can then often be spent on a better front end set up & a 12 volt (points!) conversion to better see where you are going @ the higher rate of knots..... ;)
Postby Cosmic Wizard » Fri Aug 24, 2018 8:17 pm
That's a nice looking scooter & I like the sound of your upgrades (I love engine builds), so I'll be watching with interest ;) 8-)
I've now bought 3 scooters from Marco & Steve, they're top geezers :D My latest purchase will be with me in the next few weeks, but renovation will have to wait as I'm recovering with a broken ankle after being knocked off my 750 :cry:
Good luck & make sure you post plenty of pics.
Jim
Cosmic Wizard
Postby lammydave » Sat Aug 25, 2018 6:24 am
so, The 195 kit is on... carb needs fine tuning....
there was fun on the way...(it's a lambretta)
rear brake shoes were welded to the post... this kinda thing was going to rear it's head more than once... I think the scooter must have been sat somewhere for ages..
Anyway, persuaded those off, new posts, shoes clips etc, works a treat now...
Same with front hub, shoes were solid.... spend ages with easing spray, eventually came off.... new shoes etc, now good to go....
Engine back in and fired up....
Only ignition circuit working, no other electrics,... think all the solder joints had completely dried out so ignition switch and horn/dip switch were useless...
taken them off, replaced with scootopia ones, perfect fit and everything works now.. just the brake light switch to fit as the old one is completely shot
I was particularly gutted at the ignition switch as it's got its original key... so will see if Jem Booth can recommision for me...
body work polished up a treat and all the panels are in great nick... just a big gouge in the headset, so will take the opportunity to take it back to original white colour
putting all the cables in next
got a pair of tyres and tubes from Martin Corrado, so will take the old rims off the existing very old tyres, restore the original Innocenti rims and job's a good un
Rob Skipsey is on the case with the registration process, so hopefully not too log before she's on the road!
lammydave
Postby ToBoldlyGo » Sat Aug 25, 2018 12:01 pm
Got one of these you can have if you're interested Dave?
https://www.scootopia.com/electrical/54 ... ion-switch
Postby lammydave » Sat Sep 15, 2018 6:53 am
ToBoldlyGo wrote:Got one of these you can have if you're interested Dave?
bugger, only just seen this...
lammydave
Postby corrado » Fri Sep 21, 2018 9:20 pm
What about the bottom fitting? Shocky should have links to suit with welded studs. I've got BGM top mounts if you've not already got LTH ones.
corrado
Postby HxPaul » Wed Oct 10, 2018 7:13 pm
I have one from Marco,it has a duel seat now instead of the single seats,apart from this it is the exact same scooter. https://mail.yahoo.com/d/search/referre ... llscreen=1
