Biting off more than I can chew.
Postby mark1 » Fri Aug 15, 2014 8:07 pm
I started this with the intention of, if not doing everything, doing as much as I possibly could myself. I also wanted to buy / beg everything as cheaply as possible. My thinking was that I can spend a few hours getting something back into a usable condition rather than spending top dollar on parts, thus reusing stuff people had discarded and left in the bottom of their shed or were prepared to throw out.
At the start I knew it was going to be a full frame but other than that I had no idea what I was going to build, I was just going to go with the flow and see where I ended up. Apologies that these photo's are coming in one hit, I started just after Christmas and was going to start putting the photo's on here but with one thing and another I've only just got around to it.
First thing I got were a pair of GP panels that had lost an argument with an angle grinder.
Managed to get some bits of panels that had been left over from a cut down project.
Parts started coming in thick and fast now, rear runners, mudguard, headset top and bottom, tool box door. Everything at mates rates, some of it for the cost of a couple of pints.
Everything has had the paint stripped by hand, not one of my better decisions lol.
Next up I bagged some legshields off Ebay. £3.20 plus £9 post.
I can understand why the leggies were so cheap now, ever had the feeling that someone's trying to tell you something. this came out in the leggies after I stripped them.
Indian GP frame purchased, got it for £200, not the cheapest but its got date and NOVA certs and its been stripped. Hours after hours spent on the panel work trying to panel beat them straight. I'm quite anal when it comes to distortion in panels so this is killing me. Not helped that I can't use my garage so I haven't got much room.
I managed to knock up a frame out of 3x2 to hold the frame while I spayed it.
Back in the "big garage" to get some spraying done.
Time for primer. Dispite my best efforts with the hammers, the panels are still all over the place.
Time for some filler, shame I apply it like artex.
Purchased a seat, just needs a bit of welding to get it right.
Final check on panel gap and fit. Still no idea what colour scheme I'm going to go for though
Finally happy with the leggies.
Everything primed, just got to think of what colour to spray it.
A trip to Sheffield for inspiration.
Basecoat
Just in case I missed a bit lol
Now the flake.
And masking.
Do you know what it is yet?
And now the bit I've been worrying about.............Candy
The moment of truth, unmasking.
A couple of coats of Clear then outside to dry
A few more coates of clear then block sanding and polishing.
Time to sort the engine cases out, I managed to dig some SIL GP 150 cases out of the bottom of a mates shed. I've cleaned them up and sent them to Oiltek to get them welded and converted to 200 spec.
After.
That's where I'm up to now, Going to build the forks and head set this week, hopefully get the cables and wiring loom in. I'm half way through making a twin tank conversion so need to crack on with that.
I still don't know what engine spec I'm going for. I'm having a full DC BGM ignition but still considering my options on the top end, I've got a standard 200 so depending on finances I might go for that.
I'm quite happy with how the paint has gone. The colours look superb and the masking is not bad but could be better. ah well, it was never going to be a show winner but as intended all my own work which it has been.
Thanks for looking.
mark1
Re: Biting off more than I can chew.
Postby Toddy » Fri Aug 15, 2014 8:24 pm
What a great job that must make you feel good knowing it's all your own work , super job and perseverance with the panel work and if you do as good a job on the engine I'm sure it will be a cracker these sort of stories give us all inspiration very well done , really looking forward to seeing the finished product just a shame you couldn't get it ready for the 50th anniversary weekend , top job :D
Postby Paul Slack » Fri Aug 15, 2014 8:58 pm
That is very, very impressive. Great work mate.
Paul Slack
Postby lammytv200 » Fri Aug 15, 2014 11:00 pm
Top job.
lammytv200
Postby Angry Bloke » Fri Aug 15, 2014 11:45 pm
Fantastic work 8-)
Angry Bloke
Postby dave411 » Sat Aug 16, 2014 8:16 am
Thats a brilliant job.It has inspired me to think about painting mine during its winter resto.I havent sprayed before,except with cans.Think I will give it ago in the dark months ;)
dave411
Postby coaster » Sat Aug 16, 2014 8:18 am
Some nice work there, looking forward to seeing the finished item 8-)
Postby duncan1958 » Sat Aug 16, 2014 9:33 am
Stirling effort there well done,another pile of assorted parts made whole again good for you :D
duncan1958
Postby foremanbob » Sat Aug 16, 2014 6:14 pm
Lovely job..... congratulations on a stunning paint job...
foremanbob
Postby Nigel. S » Sat Aug 16, 2014 9:07 pm
As already said, inspiring stuff. Certainly got me thinking.
Well done.
Nigel. S
Postby Scooterslag » Sun Aug 17, 2014 11:45 am
Fantastic work- every credit to you 8-)
Postby davedidsmith » Sun Aug 17, 2014 12:53 pm
Brilliant job Mark, gives me faith, however I'm certainly not good with welding (disaster last time I tried) or panel beating and yet to try spray painting. What is the name of your edging tape?
davedidsmith
Postby mark1 » Sun Aug 17, 2014 2:30 pm
Thanks for all your comments. It makes the literally hundreds of hours spent on it worth while.
davedidsmith wrote:Brilliant job Mark, gives me faith, however I'm certainly not good with welding (disaster last time I tried) or panel beating and yet to try spray painting. What is the name of your edging tape?
The edging tape was from halfords. I think it is 8mm thick. Only a quid or so.
mark1
Postby al pushpak » Mon Aug 18, 2014 7:18 pm
Fantastic job ! & very well done doing the work yourself !! look forward to seeing the end result ! al ;)
al pushpak
Postby Rich Oswald » Mon Aug 18, 2014 8:25 pm
To say that's impressive is an understatement, keep up the good work and can't wait to see it finished,
Postby HxPaul » Sat Aug 23, 2014 6:10 pm
Absolutely fantastic job,a real credit to you.Cant wait to see it finished.
Postby TED CRUD » Sat Aug 23, 2014 11:06 pm
sweet as !!!!!!!!!!!!!
TED CRUD
Postby peejay » Thu Aug 28, 2014 8:36 am
if only i was that clever, great work so far :D
Postby St George » Thu Aug 28, 2014 5:46 pm
Just proves that it can be done without being mugged, hats off to you mate,
St George
Postby datpat64 » Fri Sep 05, 2014 6:28 pm
I can't wait to see the finished bike. Make sure you put the rest of the pics up as I found this fascinating (most others did too I think).
Top job mate.
datpat64
