Dimitrios_231 wrote:What brand is the kick start shaft piston?
I bought 3 Casa recently...
dave411 wrote:MB
Dimitrios_231 wrote:Thanks,
the choke lever will look cool on the handlebars![]()
I will use one on the bridge on the next lammy.
Nobby wrote:It's fooked op that the choke works the opposite way right isn't it?!!, so you have to have the choke lever pulled fully on to have choke off..... And let the lever off to put the choke on!
Nobby wrote:
Cambridge lambretta or all styles do them I think
I've had my flywheel remagnatised and everything works but the lights are dim as fook!! Earths seem fine...Any tips anyone??
Scooterslag wrote:
Chadley wrote:I've had my flywheel remagnatised and everything works but the lights are dim as fook!! Earths seem fine...Any tips anyone??
My 6V AC lights are pretty dim at tick over. What's it like at higher rpm? Should be much better and okay for MOT purposes.
Are you running a standard 6V 25/25W incandescent headlamp bulb with a 6V 5W tail lamp and 12V 3W for the speedo? If you're using a higher wattage headlamp such as a 35/35W, it may actually be dimmer at low revs.
I notice that you have a UK DC battery type regulator/rectifier and stator but then seem to have an AC chassis loom with no battery. Shouldn't affect headlamp but brake light is likely to be dimmer at low rpm as it will be fed solely from stator rather than from DC battery.
