Series 2 survivor
Re: Series 2 survivor
Postby dickie » Sun Oct 23, 2022 1:34 pm
Having been persuaded (willingly) not to stick to standard, I haven't exactly gone extreme, but it's a long way from factory spec.
Indian gp200 gearbox went in easy with a standard shim. Just how I prefer at the tight end of the range. I've got a 5 plate, 47 tooth clutch lying about that will work well with it.
A year or 2 ago, I bought a 62/110 crank from Darrell Taylor.
It has no shims but the webs aren't machined either. This is to maintain grip on the pin.
You can see that the rod is machined to clear the cases.
It comes with a jig to hold the crank central while you check for web to case clearance; mine was at least 0.7mm and DT recommended 0.4mm to me, so I'm perfectly happy with that.
Then I dry-fitted an RT195 kit to see what I needed to do to the ports. I was under the impression that a long stroke would reduce port timings, but it seems to have done just the opposite.
So I'm not sure which way to go with these timings. I'm happy with the transfers with all packers. But, raising the barrel takes the exhaust a little higher than I'd hoped but lowering takes the inlet a little higher than I'd hoped.
I'm erring toward the 3mm packer (175ex, 127tr, 145 inlet) as these are similar, but a bit more conservative, than a 175 cast tune I did a few years ago; I was happy with that.
So what would be a more torquey motor; 170exhaust, 150inlet or 175exhaust, 145inlet?
Postby ULC Soulagent » Tue Oct 25, 2022 6:45 am
Me personally would go for 175ex 145in :D
Postby dickie » Wed Oct 26, 2022 10:14 am
ULC Soulagent wrote:Me personally would go for 175ex 145in :D
Yes, I think that's what I'll be doing. Like I said above my 175 had a slightly higher exhaust and I didn't find that particularly revvy.
Postby dickie » Wed Oct 26, 2022 8:04 pm
The clearance between the big end of the rod and crankcase mouth was a bit tight, so I had to remove the crank. It's really not sexy to hit a £300 crank with a lump hammer but I don't have the right tool to push it out.
So, I scratched my head and thought about the cheap ebay bearing puller I bought a few years ago...
It sits slightly off centre of the crank so I used a washer to apply the load.
Postby dickie » Thu Oct 27, 2022 8:48 pm
This is why I had to remove the crank. Darrell Taylor warned me about this and somehow I initially measured it completely wrong. There was something nagging away at me, so I re-checked and it was only about 0.15mm clearance between case mouth and big end of rod.
Sorted now though.
Postby dickie » Thu Oct 27, 2022 8:53 pm
Need to choose a flywheel. I'll be running full DC so I don't care about low tension coil.
The obvious one to me is a 2kg indian flywheel but I have a brand new AF 1.4kg flywheel that I bought for an abandoned project.
This isn't going to be a flying machine so I suspect such a light one would be a mistake......views?
Postby ULC Soulagent » Fri Oct 28, 2022 12:22 pm
dickie wrote:Need to choose a flywheel. I'll be running full DC so I don't care about low tension coil.
Yip use heavy flywheel
Postby dickie » Mon Dec 05, 2022 10:10 pm
I still wasn't happy with the crank clearance.
Initially, I'd only checked the Web to case clearance, but when I thought about it, the big end to case clearance seemed more likely to be an issue. This turned out to be around 0.2mm all round.
I don't have a lathe and my mate's would probably be too small to position the case anyway.
So, I tried a flap wheel with 80 grit paper. This was not as easy as I expected.
After a lot of effort and maybe an hour of farting about, the clearance was 0.4mm.
My advice is take it to a machine shop.
Postby jonw » Tue Dec 06, 2022 9:31 am
Great work... love these threads!
jonw
Postby dickie » Sun Jul 02, 2023 2:31 pm
I've done nothing on this for ages now. Largely due to cycling the pyrennees (don't do it, it's not fun) and my one-year-old grandson moving in with us, which is basically the same as being a 55-year-old dad! Fun, but hard work.
Anyway, I've managed to steal a few hours in the garage this morning and have almost got the motor finished now.
RT195 cylinder kit fitted. This is with a 62/110mm Darrell Taylor crank. Ended up with 174 exhaust, 146 inlet and 126 transfer. Squish is slightly higher than I like at 1.25mm, but it's fine for a low power plodder. It's all fitted up with three bond and silicon on the exhaust manifold, so hopefully leak-tight.
The flywheel was lapped onto the crank, when I eventually got the woodruff key out; I trial-fitted the flywheel and took half an hour to get the woodruff key free! Smoothed off the edges and all was well.
The exhaust didn't sit flush so I filed it flat and took a little off the sides of the flange.
I matched the exhaust port and manifold to the gasket, mainly just because I think it's nice engineering practice. But does anyone know if this actually makes any difference to how a motor performs? I suspect it doesn't, but that's nothing more than gut feeling.
Close enough for pit work.
Postby ULC Soulagent » Tue Jul 04, 2023 9:40 am
Doesn’t do it any harm not too match n flow ;)
Have you checked the compression ratio?
Postby dickie » Tue Jul 04, 2023 1:20 pm
ULC Soulagent wrote:Doesn’t do it any harm not too match n flow ;)
I wasn't going to bother as it's a very "normal" kit. But you've asked now, so I will. I suppose the 62mm stroke will probably raise the uncorrected ratio and reduce the corrected one, by virtue of effectively raising the exhaust port? Can't see it making a huge difference though.
Postby ULC Soulagent » Thu Jul 06, 2023 7:26 am
Hopefully you won’t need it modified ;)
Postby dickie » Thu Jul 06, 2023 4:13 pm
I'd rather not dismantle the top end now as it's covered in sealant etc.
Do you think I could reasonably accurately measure the volume without greasing the piston-bore gap, or would the fuel/oil mixture just run straight past the rings in seconds? It doesn't have to stay long, just 10 seconds or so, but it might just be a waste of time?
Postby dickie » Sat Aug 19, 2023 7:28 pm
Ran out of time to check squish as I've just been informed it'll need a DVLA inspection on Monday and I need to get it back in one piece before then!
So I skimmed up the clutch sprocket and made a baffle for the cowling. I did what is now the standard for me and cut the back of it out.
As I didn't want to damage the original one, I butchered a SIL one I had lying about.
Not pretty but very effective.
The rear brake was just dirty. I have new shoes and springs etc for it, but it simply needed a good clean up.
Just need to throw the motor in now really and it'll be good for inspection.
Then it's the fiddly cabling and electric jobs to finish it off.
Postby Storkfoot » Sat Aug 19, 2023 9:24 pm
I like what you have done with the cylinder cowling. Functional and neat :)
I have only had one inspection in recent years. I wouldn’t be too worried about having it all together. I suspect that the lad who did mine would have passed it if the engine was lying on the floor next to the frame.
Don’t quote me on that mind :D
Postby dickie » Sat Aug 19, 2023 9:32 pm
I reckon you're right. Of the 4 I've imported, 3 have been inspected! You may think I'm unlucky, or you might suspect that you make your own luck.
Like you, the folk who've inspected mine were all decent chaps, but you can't risk it, can you?
Postby dickie » Sat Aug 19, 2023 9:42 pm
Storkfoot wrote:I like what you have done with the cylinder cowling. Functional and neat :)
I don't think it's my idea. Im sure fast and furious put me on to it, but it's excellent. It can be made better by cutting the middle out of the fan cowling but I want to keep the standard look as much as possible.
Postby dickie » Sun Aug 20, 2023 10:26 am
So when I installed the engine
, the inlet manifold fouls the frame. I don't think I've had this before.
I'm using 62/110 crank, so obviously that contributes, but I'm still surprised. I've used loads of 60/110 cranks without bother and this only pushes it 1mm further. This is even using a shorter s3 shock.
Then I remembered I had this lying around, so I'll give it a try during the week after the inspection tomorrow.
Or maybe I just need to grind a bit out of the back of the manifold? I did really want to use a s2 shock to maintain its standard stance, but maybe I can't.
I reckon this is good enough for the inspection.
Postby dickie » Sat Aug 26, 2023 2:20 pm
The inspector called round on Monday and I received the V5 by Friday!
So now I want to get a hand-painted black and white number plate. But, I can't find any blank black plates. Does anyone know where I could find them? I thought this would be easy. I've got some thin plate which I could cut to size and paint I suppose.
