Storkfoot wrote:Why not buy a rusty old original and use that as a starting point?
Storkfoot wrote:A classic case of the original parts being the best. In this case, of course, without stripping the remade actuator down, you can’t see the differences.
Storkfoot wrote:Tell us about the front brake light switch please?
Storkfoot wrote:I have a weird MB loom with a couple of extra wires that seem to run the full length of the scooter. If I had seen your thread before I set up the front brake on my GP, I’d have probably fitted a front brake switch too. That said, I tend to apply both brakes at the same time anyway.
Warkton Tornado No.1 wrote:It's all looking very nice.
As you are running damper gaitors, perhaps a gaitor over the inner cable (as soon as you've made the soldered cut to remove excess) might be complimentary. Even the Indian gear/clutch gaitors can be made to function with patience. Removing all of the moulding flash takes time, but worth it IMO.
Same reason, as in being 'complimentary' but i reckon the lower damper nuts could be swapped for dome nuts for that extra finishing touch.
Just my opinionsbut I hope you don't mind me suggesting them....
As for front brake actuator switches for brake lights, I thought there might be a brake cable set available with 'non-contact' proximity switches, but I might have dreamt that up. A decent electrician might be able to tell you. Do you know any?
Users browsing this forum: No registered users and 83 guests
