Liberty - 1961 series 2 LI 125
Re: Liberty - 1961 series 2 LI 125
Postby peejay » Sun Jan 11, 2015 3:34 pm
hi Matt
great work so far, before you get everything to fit good to your frame are you confident that it is 100% straight?
just for your own piece of mind you need to know that it's right before you go to paint :)
Postby pazwaa » Mon Jan 12, 2015 9:31 am
peejay wrote:hi Matt
Thanks peejay ;)
Eerrrrmmm, no, not 100% it's straight. It looks straight, to the eye, and is in good condition. No signs of a crash and no obvious repairs.
How do I find out? What's the ramifications if it isn't?
Matt
pazwaa
Postby pazwaa » Fri Jan 16, 2015 1:54 pm
a bit more tin bashing has taken place:-
fitted the horncasting
and been working on the offside footbaord, looks a lot better now
theres a gap of about 10mm from the footboard to the underside of the panel, not sure what this should be?
and now an ametuer question. how do you stop the rear wheel spinning so i can undo the nut to remove it from the spindle?
thanks
matt
pazwaa
Postby Digger » Fri Jan 16, 2015 3:29 pm
Or if you are lucky have someone stand on the brake pedal. ;)
Digger
Postby pazwaa » Fri Jan 16, 2015 4:54 pm
Digger wrote:Image
Hi digger.
Is the photo of something you can buy?
pazwaa
Postby Nelly » Fri Jan 16, 2015 5:17 pm
Take an old wheel rim to a welding shop and show them that pic. Any decent welder could knock that up in a short space of time.
Nelly
Postby Digger » Fri Jan 16, 2015 8:53 pm
You can buy them - I made mine myself.
Digger
Postby pazwaa » Thu Apr 16, 2015 12:39 pm
been a long time since i updated this thread. work has been slow, but small moves forward
bought some trims so i can check the shape of the legshield, then do a another dry build.
ok in some places
miles out in others
bit of manipulation and i'm getting somewhere close
welded up a few small rips
need to dress them up and make them disappear.
next i'm going to get the horncast and mudguard fit.
pazwaa
Postby soullad » Thu Apr 16, 2015 1:40 pm
More often than not, it's the trim that's needs shaping to the leagues, not so the other way round
soullad
Postby pazwaa » Fri Apr 17, 2015 10:57 am
soullad wrote:More often than not, it's the trim that's needs shaping to the leagues, not so the other way round
Thanks for the info. Do you know if that radius is supposed to stay the same across the bottom of the legshield or does it change towards the edges?
The trim was cheap stuff, just bought for reference.
Matt
pazwaa
