GT200 60's style racer
Re: GT200 60's style racer
Postby pauLI » Mon Aug 01, 2016 8:28 am
Thanks again for all the positive comments
The Painter is called Leon Bugbee and is based in Halstead, Essex
He can be found of fb or contact me if you want his number etc
cheers
pauLI
Postby gaz_powell » Mon Aug 01, 2016 10:05 pm
The colour scheme is excellent, the purple and green really set off the white ......best socks I've seen in ages, where are they from? ;)
Ps canny bike KTP
Postby Nudger » Tue Aug 02, 2016 8:17 am
VERY nice & definitely stands out from the crowd (for a good reason).
Is there any story behind the racing number? Just wondered....
Nudger
Postby pauLI » Tue Aug 02, 2016 2:02 pm
No story as such
Its an made up of the date I got married 5-6-2009
pauLI
Postby WXboy64 » Wed Aug 03, 2016 9:43 am
Superb Paul....really proud to have put her back on the road, then to see the new guise. I knew that Jarv had done some work on it as I sold the 175 to a Wymondham lad and he said that he had seen it being worked on. Well done - enjoy! - Keith
WXboy64
Postby Rich Oswald » Sun Aug 07, 2016 3:24 pm
Very nice indeed. Don't normally like tri-colour scoots but works very well.
Postby Gtwildcat » Sun Aug 07, 2016 4:56 pm
Very nice, where did you get the rear rack from?
Cheers john
Gtwildcat
Postby Paul_from_Thornbury » Tue Aug 09, 2016 9:57 am
Just changed my inline spare wheel holder from the Cuppini style to the one you have here, as the Cuppini one which was made out of sheet plate and kept vibrating and snapping.
having just fitted my one like yours I note the same issue you have is that the two half clamps come together and don't meets any bolt holes if you want the wheel mounted as yours with the spare holes at 3/6/9/12 o clock to mount an oil can holder.
When the clamps come together like this they don't even catch the wheel rim as it is scalloped. So what exactly is clamping your wheel or is it just wedged between the holder and the toolbox door.
I only have a 3.00x10 tyre and its a squeeze with the tyre wedged against the toolbox door, at least there was a small gap at the toolbox with the Cuppini style.
Can you send me some close up pictures of the clamp and the toolbox?
cheers Paul
Paul_from_Thornbury
Postby pauLI » Tue Aug 09, 2016 4:13 pm
Paul_from_Thornbury wrote:Just changed my inline spare wheel holder from the Cuppini style to the one you have here, as the Cuppini one which was made out of sheet plate and kept vibrating and snapping.
cheers Paul
Hello mate
I have an original hinged swing out type carrier, dunno if this is the same you have or not but the tyre 3.00x10 fully inflated sits tight against the tool box door and doesn't move in the carrier at all.
I have the clamps done right up and it seems to work fine
pauLI
Postby Paul_from_Thornbury » Tue Aug 09, 2016 5:28 pm
Do your clamps touch the wheel rim or not?
Attached is a picture of mine when I put the spare bolt holes at 3/6/9/12 o clock positions?
My spare is just jammed between the rack and the toolbox door and isn't being held by the clamps.
I've seen pictures on here where the clamp actually uses one of the spare holes, but that makes it difficult to fit an oil tank holder as all the holes are then not in good places and you definitely need a scooped toolbox door.
Paul_from_Thornbury
Postby pauLI » Wed Aug 10, 2016 2:25 pm
Paul_from_Thornbury wrote:Do your clamps touch the wheel rim or not?
Hello mate
the clamps touch the wheel rim yes, where they bend inwards before they bend upwards for the fixing bolt. if I was to grab the wheel and pulled it upwards it wouldn't move. Yours looks like there is a considerable gap between the clamp and the wheel and the fixing area looks different to mine to
I will try and get some pictures tonight (time permitting)
With regards the recessed tool box door, you would only need this if you had a fully inflated 3.50 x 10 tyre fitted
cheers
pauLI
Postby steveiow » Sat Aug 20, 2016 8:45 pm
Superb :D
steveiow
Postby Topgearskin » Wed Jan 18, 2017 4:55 pm
Such a great looking Scooter and (I'm sure) well worth the ball ache in the end!
I'm interested to hear your views on that Seat? is it as comfortable as it looks?
Topgearskin
Postby peter357bikes » Mon Jan 23, 2017 7:31 pm
Simply beautiful.
peter357bikes
Postby citydaz » Tue Jan 24, 2017 9:53 pm
wow!
thats a really nice looking scoot.
just love the colour scheme - they work really well together.
Well done mate
citydaz
Postby byron » Tue Jan 24, 2017 11:02 pm
only just seen this Paul!
looking good.
and glad all the electrics worked again after the rebuild, following our facetime sessions
byron
Postby wellerchap » Thu Feb 02, 2017 2:42 pm
Great work dude - and nice to see a homage to a cherished garment too :D
wellerchap
Postby pauLI » Fri Feb 03, 2017 8:58 am
Topgearskin wrote:Such a great looking Scooter and (I'm sure) well worth the ball ache in the end!
cheers mate, plenty off ache along the way, as you well know
Its the most comfortable seat i have, but then not much is comfy with my bony ar*e
pauLI
Postby pauLI » Fri Feb 03, 2017 8:59 am
byron wrote:only just seen this Paul!
looking good.
Indeed Jarv, without the facetime i doubt i'd have got them electrics sorted, much obliged to you
and for the initial work on the conversion etc
pauLI
Postby pauLI » Fri Feb 03, 2017 9:00 am
wellerchap wrote:Great work dude - and nice to see a homage to a cherished garment too :D
Like
pauLI
Users browsing this forum: Bing [Bot] and 182 guests
