SX150 / RB225 winter project
Re: SX150 / RB225 winter project
Postby shane BBoys » Sat Apr 18, 2015 6:57 pm
Looks great keep the pics coming.
shane BBoys
Postby shane BBoys » Sat Apr 18, 2015 7:02 pm
Looks great, good choice of design. Keep the pics coming.
shane BBoys
Postby Covboy » Sun Apr 19, 2015 2:52 pm
More painted parts.
Postby wellerchap » Sun Apr 19, 2015 5:19 pm
This is going to be a pearler, I can tell !
wellerchap
Postby Covboy » Sun Apr 19, 2015 7:07 pm
Today's effort- doesn't look much but it took ages to get the toolbox and tank in properly.
Postby Rich Oswald » Mon Apr 20, 2015 6:49 pm
That looks nice, be good to see this finished,
Postby Covboy » Mon Apr 20, 2015 10:07 pm
Stand and mudguard fitted.
Q : Do the mudguard fixing bolts fit from the outside , nuts & washers on the inside or vice versa? The reason I ask is because the restoration blog shows bolt heads on inside of the mudguard, but SR exploded parts diagram shows nuts & washers on the inside. Or does it even matter ?
Engine ready for test fitting. I'm concerned that the tank cut out and standard toolbox arrangement won't provide enough space for the dellorto 34'mm carb. I dry fitted the panels, tool box and engine but not with the carb....doh!
And my new offset frame cones don't fit flush with the frame tube. Even with the overspray removed. I'm going to have to dig out the old original ones and compare them
Postby Covboy » Tue Apr 21, 2015 10:16 pm
Engine in. Carb fits ok and there seems to be enough space with and without rider load.
Postby shane BBoys » Wed Apr 22, 2015 11:33 pm
Hi did you manage to get the off set cones in? looks tight for the throttle cable!
looks great all the same.
Shane.
shane BBoys
Postby Covboy » Thu Apr 23, 2015 7:44 am
Hi Shane
Yes - the finish on the new cones was rough compared to the old ones - I just rubbed them down until smooth and they now fit.
Re the throttle yes - very tight !- I've ordered a 90' elbow- when I sit on the seat the carb moves downwards creating more space between the tank so as long as there is enough room unloaded it should be ok...
Next job forks .
Postby shane BBoys » Sat May 02, 2015 4:36 pm
How do?
I put my forks in 1st this works a treat strapping the front end down
Hope you didn't struggle to much.
Cheers Shane
shane BBoys
Postby Covboy » Mon May 04, 2015 10:23 am
Hi Shane
Forks assembled and on no problem - but they do feel much stiffer than my li150 forks - could be because I used progressive springs - might have to change them if they feel too hard on on road .
Cables and wiring next...
Postby Covboy » Wed May 13, 2015 7:38 pm
Bit more work - coming together nicely now ... Progress gets halted due to missing parts that I thought I'd ordered then can't find. So I order them, wait two days for the delivery and then find the original parts ! Very annoying - happened more than once - it must be my age... :roll: They will come in useful for the next project though!!!!
Postby Made In Sheppy » Thu May 14, 2015 6:27 am
Looking good
Made In Sheppy
Postby Covboy » Fri May 15, 2015 5:22 pm
Minor fettling left and engine checks then it's mot time
Thinking about a SIP speedo...yes or no....?
Postby dickie » Fri May 15, 2015 8:01 pm
If you're going to install temp sensor definitely yes.
If you just want speedo accuracy then no; doesn't really matter how fast your speedo is telling you unless your license is in jeopardy and as they exaggerate you're on the safe side with cheap Indian ones.
Postby Tim_Craig » Thu Jun 18, 2015 8:27 am
Very nice project that.
Tim_Craig
Postby Covboy » Fri Jun 19, 2015 7:43 am
No long now til completion.....engine being sorted & ported and should all be up and running next week ready for mot...can't wait !!!!! :D
Postby Covboy » Fri Jun 19, 2015 2:49 pm
Here are some close ups of the details I like....
Postby shane BBoys » Fri Jun 19, 2015 7:28 pm
Looks fab I'm bet you are cuffed with the overall finish. How tight were the cables on the carbin the end?
shane BBoys
Users browsing this forum: Baidu [Spider] and 54 guests
