from rusto to resto
Re: from rusto to resto
Postby Cheersdude » Sun Dec 28, 2014 4:24 pm
Engine now fitted. Had to get some offset cones and have the rear shock on its lowest setting, but the manifold is tight to the frame. And the front brake which I thought I'd set up is useless, hope it just needs bleeding, as striping down the front end will be a nightmare!..... Why did I go for a hidden set up
Cheersdude
Postby Covboy » Sun Dec 28, 2014 9:06 pm
Nice scoot - love the Orange....
Postby wellerchap » Sun Dec 28, 2014 9:53 pm
That's a corker - a right Bobby Dazzler!
wellerchap
Postby smithy » Mon Dec 29, 2014 11:10 am
wow!! a beauty 8-)
smithy
Postby dave411 » Mon Dec 29, 2014 12:20 pm
That is amazing.Well done.
dave411
Postby garynonnah » Fri Jan 02, 2015 7:00 pm
amazing scoot....well done fella
garynonnah
Postby Cheersdude » Sat Jan 24, 2015 9:30 am
MOT done and finally out on the road. Ended up stripping the front end and replacing the cable section of the semi hydraulic brake and re-bleeding the brakes. They still feel a bit spongy but they passed a MOT so can't be that bad!!. Also change the levers to a set of adjustable one which I had fitted once then change my mind about, still not sure about them though.
have to have the brake one set to 6 or I can't get the pull on it to operate the brake and the clutch one on 3. I'd probably be better off with one dog leg and one standard. I've ordered up some different levers to have a play around with.
TS1 recommended running in mileage,500 to be safe?
Cheersdude
Users browsing this forum: No registered users and 90 guests
