Not sure what to do about this, but I'm not just leaving it. Maybe try white vinegar like nobby did in his very entertaining video?
Storkfoot wrote:Very resourceful![]()
Are you using the original loom?
dickie wrote:Storkfoot wrote:Very resourceful![]()
Yes, I'm keeping as much as I can original. There's no reason why a loom will fail other than at the connections. I've flowed solder into some of the original bullet crimps and i always apply grease when I connect them. Due to going full DC, there are a few mods, but I've done my best to hide them.
The cable outers are original too. I tried to use the original inners by taking them out and cleaning them, but they weren't good enough. Once i replaced the inners, all actions were unsurprisingly much nicer. The throttle cable was a little tricky, but a barrel adjuster for a classic bike plus about 100mm of offcut new outer means it works with a 25phbl.
Rich Oswald wrote:dickie wrote:Rich Oswald wrote:No teaching you to suck eggs Dickie, but did you look under the fuel cap handle, in the centre, for the breather hole? Sorry if that is obvious.
I take no advice as insulting; nobody knows everything even if they think they do. But yes, I did check and was surprised to see it didn't have one. As I type this, I'm wondering what even made me look in the first place!
What prompted me to ask this was, I restored S1 quite a few years ago now and it would only run for a few minutes before cutting out. Found out that it was the original fuel cap with no breather hole. A new cap cured it.
Users browsing this forum: No registered users and 86 guests
