Li Series 3 - Gran Turismo 186 kit
Postby Covboy » Tue Jan 20, 2015 10:03 pm
Hi here is my first scoot - originally a standard 150 series 3 . I have had it for 3 years, restored it and ridden it for 2 years. I decided to fit a GT 186 kit and found the time this weekend. Found it straight forward exercise to do - the best bit was when I kicked it over, it started - what a great sound. Took it out for a short test ride - the difference in power is unbeliveable -it's fierce compared to what I have been used too. .........can't wait for a dry day...
The kit comprised of
GT 186 Barrell & piston
GT porcupine head
42mm rayspeed clubman exhaust
dellorto 25mm carb and reed valve manifold
Re: Li Sieries 3 - Gran Turismo 186 kit
Postby Covboy » Tue Jan 20, 2015 10:12 pm
Nice enamel badge to fit on the legshield
Re: Li Series 3 - Gran Turismo 186 kit
Postby Toddy » Wed Jan 21, 2015 7:17 am
Nice scooter , i think you will be pleased with the GT kit ive heard good reports , ive just fitted the large block GT kit in one of mine so hoping for the same and i didnt get a badge with mine :cry:
Postby Covboy » Wed Jan 21, 2015 8:37 am
Hi Toddy
You can get the badges fron Gran Sport in Birmingham or direct from Gran Turismo
They are pin badges - cut off the pin and use strong number plate tape to fix
Postby Covboy » Fri Jan 23, 2015 3:23 pm
The finishing touch ! A shiny GT badge now affixed to the legshield.
Might consider a disc brake in the summer after I have ridden, depending if the current brakes stop it quickly enough!!!...
