New GP
Re: New GP
Postby shane BBoys » Tue Apr 07, 2026 4:30 pm
Gaz.
That looks cool as, can I ask how you yellowed the lens I have a Lucas on my jet and I think that it would look better with a yellow lens?
Cheers Shane.
shane BBoys
Re: New GP
Postby gaz_powell » Wed Apr 08, 2026 9:58 pm
With great difficulty....
You can buy a special spray, but that would have been easy... I bought headlight film and it was a nightmare due to curves in both directions and the final turn on the edge.
Took 3 very frustrating goes...
If you want to use a film get someone who does it every day.... I would try the paint
Re: New GP
Postby shane BBoys » Thu Apr 09, 2026 8:18 am
gaz_powell wrote:With great difficulty....
Cheers Gaz.
I had seen the film and a guy on you tube fitting it to his lens and also thought spray would possibly be easier.
Cheers Shane.
shane BBoys
Re: New GP
Postby SlackerThePinstriper » Thu Apr 09, 2026 3:52 pm
Buy glass paint from somewhere like hobby craft, brush it on, jobs a good un, been using it for years.
In my defence it has a Lammy mudguard and seat 8-)
Re: New GP
Postby shane BBoys » Fri Apr 10, 2026 12:24 pm
Wayne.
I have ordered the spray yesterday unfortunately what could go wrong?
Mucho!
shane BBoys
Re: New GP
Postby SlackerThePinstriper » Fri Apr 10, 2026 1:39 pm
shane BBoys wrote:Wayne.
Mucho!
Nowt some thinners won't fix if it goes tits up.
I've also used candy yellow in a rattle can on headlights
Re: New GP
Postby gaz_powell » Mon Jun 22, 2026 9:49 pm
Bit of an update...
300 miles in became a sod to start... Usual checks, cdi, stator, carb, plug, lead etc.
No avail... So only left with compression.. And yep it was.
As I slid the barrel off I could see the top ring gap was not were it should be. The rings were gapped on assembly and fitted correctly.
It appeared the ring had worn the peg.. Crap peg??
The top was doing the same but hadn't moved.
And spun, but had stayed in the groove.
Stripped it down, put some new rings in the barrel to see what gap was like and it's in tolerance, so will go again on 64mm. Bit worried it may have ovalled the bore, so will get it checked out and see what route.
Anyway it's a Scootopia 185 top end now and needs running in again!! This was fasted way to get back on road.
Re: New GP
Postby dickie » Thu Jun 25, 2026 10:35 pm
Will it make it to barnsley though?
Re: New GP
Postby gaz_powell » Mon Jun 29, 2026 9:27 pm
dickie wrote:Will it make it to barnsley though?
It didn't set out... Had something else on...
Will be Staithes now, as its TS1 for Porthmadog
Users browsing this forum: No registered users and 81 guests
