Fuel vapour blowing out the carb
If you have any carb parts which you no longer require, and are willing to swap for others, including jets, slides, needles etc... please post the details here for other Forum members to see. Contact should be made using the Forum's PM system
Postby Trevor S » Thu Feb 23, 2023 11:57 pm
When I run my 1967 SX200 with the air hose off, there is fuel vapour blowing out the carb mouth when I
rev the engine. I have noticed fuel dripping out of the drain tube with the air hose in place.
The Dellorto carb has been cleaned fitted with all new gaskets, slide, and fuel cut off valve etc.
I have never had a Lambretta that did not leak fuel out the drain tube a little however I think this
is a bit much.
Anyone solved this?
Trevor S
Trevor S
Re: Fuel vapour blowing out the carb
Postby hullygully » Fri Feb 24, 2023 9:32 am
how old is the bore to piston to rings bud?
does the piston match any tuning work done on the barrel?
timing?
carb & jetting?
Postby hullygully » Fri Feb 24, 2023 12:54 pm
think you need to place this in the carb section bud ;)
Return to Carb - Swap Shop
