Fixing leg shield badge
Postby AAVlover » Fri May 12, 2017 10:22 pm
Hi - i have chromedthe existing badge, and it has small holes for fixing to the holes in the legshields. Evidently later model badges had pins which were then 'pressed' to make the fix. How do you fix the ones with holes, the holes seem too small for rivets and too small for 'hammer screws', any suggestions gratefully received???
AAVlover
Re: Fixing leg shield badge
Postby jbcollier » Sat May 13, 2017 2:34 pm
A photo would help. Rechroming usually "thickens" the item which often leads to loss of detail and fit issues. Perhaps you may need to open up the mounting holes so the pins fit.
jbcollier
Postby AAVlover » Wed May 17, 2017 11:17 am
Hi - see photos enclosed
AAVlover
Postby jbcollier » Wed May 17, 2017 7:59 pm
The pins don't fit, where?
jbcollier
Postby AAVlover » Wed May 17, 2017 8:10 pm
you can see the small holes in the badge, and the holes in the legshields, they are 2mm holes and whilst I can use micros screws and nuts, I'm looking for a 'cleaner' method of fixing the badge to the legshields
AAVlover
Postby jbcollier » Thu May 18, 2017 2:26 pm
SIP, and I'm sure others, sell soft rivets in various diameters and lengths. Search their site for "rivet" and you should be able to find a size that will work.
jbcollier
Postby AAVlover » Thu May 25, 2017 10:53 pm
Solved, thanks
AAVlover
