Model d exhaust
Model d exhaust
Postby Trotter68 » Wed Apr 05, 2017 6:17 pm
Hi all need advice got a standard d 125cc engine with a aberth exhaust not running to well carb issue do I need to up jet the carb if so by how much
Trotter68
Re: Model d exhaust
Postby jbcollier » Thu Apr 06, 2017 2:02 pm
Can you give us more detail.
- You seem to imply it was running fine until you fit the exhuast. True?
- Not running well. What does that mean? Not idling? Not starting? Bogging at high speed? Bogging at low speed?
- Have you stripped and cleaned out the carb?
- Jets clear?
jbcollier
Users browsing this forum: Google [Bot] and 48 guests
