Model C stiff gear change
Postby johncas » Sun Feb 05, 2017 9:28 pm
The gear change on my model c is rearly stiff not smooth I know it's only single cable where the D and LD 150cc's had twin cable on mine you have to force it into 1st gear then rearly stiff getting into 2nd when the gear selector says 2nd you not actually in 2nd is there anyway to make the gear change smoother the book of thelambretta says cable required lubricating should I give that a go or is there somthing else I can try
johncas
Re: Model C stiff gear change
Postby Rob Miller » Mon Feb 06, 2017 8:15 pm
If you havn't already done so, fit a new cable and possibly a new roller kit in the handlebars. oversized roller kits are available to take up any wear in the handlebars. Use plenty of grease. I got my parts from Rimini.
Rob Miller
