jbcollier wrote:Clean everything up carefully and watch to see where it's coming from. There are three types of oil:
- 140 gear oil in the final drive, most like to leak from the rear wheel oil seal. Later cases added a breather which helps a lot.
- 30 engine oil in the tranny, overfill as mentioned above, loose plugs, gaskets, etc.
- 2 stroke mix, yup I once ordered gaskets and seals because I had a fuel leak -- thankfully I figured it out before stripping the engine. The fuel taps are notorious for leaking. The petrol evaporates leaving, you guessed it, oil.
Steve J wrote:. Hope that's of some use!
