Silent blocks
Silent blocks
Postby Trotter68 » Mon Jan 09, 2017 9:36 pm
Hi any one got advise on removing the silent blocks .is there a tool I can buy that fits model d
Trotter68
Re: Silent blocks
Postby jbcollier » Tue Jan 10, 2017 2:52 pm
I just used a large, long bolt and nut with sockets and washers sized to suit.
jbcollier
Re: Silent blocks
Postby Trotter68 » Tue Jan 10, 2017 5:08 pm
Trotter68
Re: Silent blocks
Postby Steve J » Tue Jan 10, 2017 9:19 pm
Heating the alloy causes it to expand a little, which makes it a bit easier to get the old ones out. Sometimes it overheats the old silentblocs, so a job best done in the open. When fitting the new ones, put them in the freezer for a few hours, and heat up the alloy casting - it all helps!
Steve J
Re: Silent blocks
Postby mm man » Wed Jan 11, 2017 12:22 am
I drilled lots of holes in the rubber until I could knock the centres out then cut the outer steel ring with a hacksaw.They came out very easy with no damage to the engine case
Then fitted the new ones with the bolt and socket method mentioned .
The whole job was a lot easier than I expected took around 45 mins to an hour .
Good luck
mm man
Re: Silent blocks
Postby Trotter68 » Wed Jan 11, 2017 4:00 pm
Thank you guys
Trotter68
