Model d clutch bell housing
Postby Trotter68 » Sat Dec 31, 2016 10:01 am
Hi can somebody please tell right or left thread on the nut that holds the clutch bell housing
Trotter68
Re: Model d clutch bell housing
Postby Steve J » Sun Jan 01, 2017 11:12 am
The large nut which holds the clutch bell to its bevel gear is a normal right hand thread. The trick is to hold the sleeve which the nut screws onto in place - you'll need a slim open ended spanner inserted through the hole for the kickstart bevel gear, held onto the two flats on the sleeve itself, to prevent it from turning whilst you undo the nut. It's also a good idea to wrap the shank of the spanner with insulating or gaffer tape, to stop it marking the alloy around the kickstart aperture. :idea:
If by any chance you're talking about the 14mm nut on the very front of the splined block which the clutch friction plates fit onto, that has a left-hand thread - unless yours is an early model, when you might just find it's right-handed.
Steve J
Postby Big Al » Sun Jan 01, 2017 12:13 pm
Talking of left and right hand threads, and just in case you work on the flywheel, Steve pointed out to me earlier that:
"The flywheel retaining nut on the D/Ld crank is a normal right hand thread - the flywheel rotates in the opposite direction compared to the Li/Tv/Sx/GP. No need for a left hand thread there!"
Big Al
Postby Trotter68 » Sun Jan 01, 2017 12:44 pm
Thanks for the replys
Yes it's the 14mm nut that is inside the spline my is a 1953 model
Trotter68
Postby Steve J » Sun Jan 01, 2017 1:47 pm
Probably a right-hand thread in that case - a 1953 model would be classed as an early model, and there's probably no tab washer to hold the nut in place, either.
Steve J
Postby Trotter68 » Sun Jan 01, 2017 3:14 pm
Thanks Steve I'm try to take the chrankshaft out think I might wait for the repair manual I have ordered
Trotter68
Postby Steve J » Sun Jan 01, 2017 3:25 pm
OK - be aware of the differences between the early Mk1 125 engines and the later Mk2 125 &150 engines. A lot of parts are interchangeable, but the crankshafts, main bearings, oilseals, cylinder and head, are very different.
Steve J
Postby Trotter68 » Sun Jan 01, 2017 3:30 pm
Steve I've got flywheel of the nut that splits the crankshaft has sheared so has to come out ,I was going to buy a crankshaft repair kit for it also cylinder head and barrel are good but need new piston which has 3 rings
Trotter68
Postby Steve J » Tue Jan 03, 2017 9:34 am
Just make sure you get the piston with the 14mm gudgeon pin!
Steve J
Postby Trotter68 » Tue Jan 03, 2017 3:19 pm
Will do thanks
Trotter68
Users browsing this forum: No registered users and 8 guests
