by Big Al » Thu Dec 15, 2016 3:44 pm
If I loosen the kickstart pedal and remove it from the splines, will this release the spring, or can the pedal simply be replaced later on in the same position, without the need for any further action?
Big Al
by jbcollier » Thu Dec 15, 2016 5:13 pm
Removing the pedal will not release the kickstart return spring. You can easily remove and replace the pedal with no problem.
jbcollier
by Big Al » Thu Dec 15, 2016 9:24 pm
Many thanks, John.
Big Al
