Model D front mudguard holes?
Postby mm man » Mon Aug 01, 2016 10:48 am
Hi could anyone please tell me what are the two holes in the sides of the front mudguard by the top fixing bracket for ?
I have seen that some scooter shops sell new mudguards with the holes already in ?
I am getting ready for paint so I need to know if I need to leave or fill the holes .
Thanks for any help in advance
mm man
Re: Model D front mudguard holes?
Postby jbcollier » Mon Aug 01, 2016 1:38 pm
The holes are for grey rubber buffers to keep the fender from hitting the fork as the fender is a tight fit into the fork.
https://jbcollier.smugmug.com/Scooter/i-4NjBV77/A
jbcollier
Postby Big Al » Mon Aug 01, 2016 4:41 pm
This PDF parts book will probably help you with the rebuild.
http://www.scooterhelp.com/serial/LD_D.parts.html
The buffer is in Section XIX, Panel and Frame Components, Figure 111 (Part No. 15060039).
Big Al
Postby mm man » Mon Aug 01, 2016 10:37 pm
Thanks guys for your help again its much appreciated
mm man
