Model d legshield support bars
Postby mm man » Sat Jul 30, 2016 9:25 am
Hi can anyone tell me how many support bars go through the frame to hold the legshields ?
I have one bar at the front of the frame and two holes in the frame behind that of the same diameter given the impression there should be three bars?
I don't want to weld any more bars in if incorrect. I have done some google searches and I see some with one and some with two bars ?
If these holes are not for supports what are they for ?
Thanks in advance for your help
mm man
Re: Model d legshield support bars
Postby Rob Miller » Sat Jul 30, 2016 10:11 am
You need another 2 bars fitting through the holes in the frame but NOT welded. Only the front bar is welded which is why the other two are missing.
Rob Miller
Postby mm man » Sat Jul 30, 2016 10:42 am
Nice one Rob thanks for that
mm man
Postby Big Al » Sun Jul 31, 2016 11:36 am
On mine, the middle one of the three bars carries a cable guide, part no. 11180151, to the right (rear brake pedal side) of the horizontal main frame tube.
It was fitted on the bar, between the frame tube and the innermost of the two legshield fitting holes in the bar.
Big Al
Postby mm man » Sun Jul 31, 2016 6:34 pm
Big Al wrote:On mine, the middle one of the three bars carries a cable guide, part no. 11180151, to the right (rear brake pedal side) of the horizontal main frame tube.
Thanks for that I will check that out on my frame
mm man
Users browsing this forum: No registered users and 22 guests
